List pricing is USD$250! And for the gamer crowd it naturally has all kinds of LEDs.
https://www.evga.com/articles/01281/evga-nu-audio/
Specifications:
Audio DSP:
XMOS xCORE-200
Native DSD Support (up to x256)
Output Configuration:
2 Channel (Analog)
5.1 Channel (Digital via S/PDIF)
Dynamic Range (DNR) / Signal-to-Noise (SNR):
123dB (Stereo Playback)
121dB (Line-In Recording)
Playback Format:
Up to 384kHz, 32bit (Stereo)
Up to 192kHz, 24bit (Optical)
Headphone Amp:
16-600ohm (Independent Analog Control)
Maximum Voltage:
8Vrms
Maximum Current:
250mA
Recording Format:
Up to 384kHz, 32bit (Line-In)
Up to 192kHz, 24bit (Mic-In)
RGB Lighting:
10 - Mode w/ Audio Reactive Lighting
I/O:
Stereo Out (RCA L/R)
Headphone Out (6.3mm)
Line-In (3.5mm)
Mic-In (3.5mm)
Optical Out (TOSLINK Passthrough)
Front Panel Header
Premium Components:
DAC - AKM AK4493
ADC - AKM AK5572
OP-AMP (Headphone) - ADI OP275
OP-AMP (Line Out) - ADI AD8056
Capacitors - WIMA, Audio Note(UK), Nichicon
Power Regulators - Texas Instruments TPS7A47/TPS7A33 ultralow-noise power solution
Switchable OP-AMPs:
Headphone, Line out
Interface:
PCIe x1 Gen2
Power Connector:
1x SATA Power
Supported OS:
Windows 10, 8.1, 7
Specifications:
Audio DSP:
XMOS xCORE-200
2 Channel (Analog)
Playback Format:
Headphone Amp:
Maximum Voltage:
8Vrms
Maximum Current:
250mA
Recording Format:
RGB Lighting:
I/O:
Line-In (3.5mm)
Mic-In (3.5mm)
Front Panel Header
Premium Components:
DAC - AKM AK4493
ADC - AKM AK5572
Switchable OP-AMPs:
Headphone, Line out
Interface:
PCIe x1 Gen2
Power Connector:
1x SATA Power
Supported OS:
Windows 10, 8.1, 7
