We can understand the concepts a bit without getting too deep.
Like much in acoustics, it's fundamentally about distance versus wavelength, connected by the speed of sound.
Because the 2 sources are in fixed locations, their phase relationship is different at every wavelength/frequency AND also across the polar pattern. This develops exactly the same sort of complex interference pattern as monopoles or dipoles; it's only the exact details that change.
I think I've set this up correctly in VituixCAD.
- A pair of imaginary drivers with perfectly flat frequency response & omnidirectional dispersion, i.e., ideal point sources.
- 200mm spacing between them. This is good to experiment with, but 200mm covers a useful span of midrange.
- Because the 2nd driver is 200mm farther from the imaginary microphone, its amplitude is increased 0.9dB to match the main driver's. (In the real world, you need to EQ to match FR as well.)
- We'll keep all of those things constant while altering the 2nd driver's delay & polarity.
Monopole - no delay, positive polarity. This shows essentially perfect omnidirectional behavior up to 500Hz. Higher, we see massive comb filtering on the main axis & serious lobing elsewhere.
Dipole - no delay, inverted polarity. Massive cancellation below ~250Hz, an octave below the monopole's transition. A nice dipole pattern covers the 2 octaves from 300Hz to 1.2kHz. The same combing & lobing above, but nulls & peaks switch. No surprise that this matches the monopole's results only reversed.
Cardioid - 580us delay (200mm spacing, or 1 wavelength at 1.7kHz), inverted polarity. The gradient behavior again drops by an octave or so, giving a good pattern from roughly 150Hz to 700Hz. Combing & lobing yet again, though a very narrow null directly behind the speaker remains clean.
The driver spacing causes LF reinforcement when both have the same polarity, while cancelling in designs with one inverted. Just as in a dipole, the cardioid's secondary driver nulls the main output at all angles, once the wavelength becomes long enough to overwhelm the geometry.
(Note that both Kii & Dutch^2 use monopole subs below 100Hz or so.)
Regardless of the configuration, 2 drivers with this spacing will exhibit major lobing at higher frequencies. The waves simply cannot combine properly when the sources are a significant fraction of a wavelength apart.
So, covering 2 octaves isn't too hard, 2.5 appears reasonable. More than 3? You're gonna need 2 cardioids or another way to control directivity.
(Note that this bandwidth fits a 4-way, which is pretty much where all of the serious DIY - read "doesn't need to be marketable" - builders end up. If you're beginning to suspect that physics & our hearing have conspired just to annoy loudspeaker designers, we're on the same page.)
