Thighsofsteel
Are these devices available to purchase yet? Seems like they arent arriving at various UK suppliers for a couple more weeks.
But it looks great on marketing flyers and it convinces audiofools.an SFP port is crazy lol, I only see that on server gear. never really understood why equipment with digital only outs demands a premium over their DAC-bearing equivalents, pay more to do less?
don’t mean to poopoo, there are an increasing number of great active speaker options that will happily take AES3 or S/PDIF, and I wish those outs were on more equipment.
Jitter in network traffic?The SFP Port is there to prevent those nasty little jitter bugs from crawling in through an electrical network connection. Can't be to cautious!
Marketing and audiofools are buying into it.Why on earth would they include a SFP connection?
Hey, if someone wants to do a hardwire connection from their switch in the van down by the river 200 meters away from their house to their streamer, that SFP port is going to come in very handy. After they finish the trench, of course.Marketing and audiofools are buying into it.
I'd start by sending a message Topping Support.Good morning,
I’m having a problem with communication between the Eversolo T8 and the Topping D90 III Sabre via I²S.
The Eversolo has several I²S configuration modes, as well as ISS MUTE settings for Low and High. The Topping also offers ISS MUTE Low, High, and Off.
Based on the technical specifications and manuals for both devices, I should select Mode 1 on the Eversolo to achieve compatibility with the Topping. However, there’s a problem with the ISS MUTE behavior:
- When both devices are set to Low or High, there’s no sound.
- When one is Low and the other High (or vice versa), I get pops and clicks in the right channel.
- When I set the Topping’s MUTE to Off, everything plays fine until I change the album or press pause/play — then the popping noise returns again.
Restarting the DAC (turning it off and on) helps temporarily, but it’s very frustrating.
What should I do?
I’d prefer not to use USB, as in my opinion the sound quality over I²S is noticeably better.
In my opinion I2S is just another audiophile affectation, there isn’t even an agreed standard.Good morning,
What should I do?
USB will be completely transparent and blameless.
Having said that I understand you would like to solve the issue so would contact Kim at Eversolo support on the Zidoo forum.
Eliminate what variable?I have ordered SFP converters and optical cable for about $60, that is not much to eliminate this variable.
I've just noticed this thread - You're spending a fortune (Even trade prices) on gear like this and some of the finest performing speakers out there and you have the audacity to be showing one of the worst, deliberately distorted and most heavily compressed recordings out there???It works!View attachment 481589
S'alright Keith, I can't bloody well talk!!!I used to and still like a few of the songs and I would much rather listen to music I like than the most perfect recording of something I don’t.
Having said that if you came around to audition speakers I might play some decent recordings first!
Do you think it sounds better on stands? Taller image?
Of course it does otherwise why put them on speaker stand?Do you think it sounds better on stands? Taller image?
