Maybe buy a DAC cable for the connection to the sfp port of the switch. (DAC.. as in direct attach cable). Very cheap. (Or are those sfp+ only?)
Read up thread.An SFP connection is not going to make your music better or quicker to come out of your speakers .. Still no idea why it’s on Hifi equipmentI wonder if it will be present on the Z10?
Just saying that if he really wanted to use the sfp port (maybe attaching a second network for whatever reason.. I know it's unlikely) a dac even if copper would be cheapest way.. like 10 bucks and done. As long as tht's compatible with sfp. The port wouldnt even know about the actual medium./, right? Could of course also be an active optical "direct" cable.. still cheaper than 2 real sfps (let alone the power they draw)DAC = Copper
AOC = Fibre
The only possible point of the SFP cage on the T8 is to offer the ability to optically isolate it from a network (I'm not suggesting that this is in any way required, i'm just pointing out why it is there from a marketing perspective). There is therefore no point plugging a DAC into the SFP cage, you might as well use the RJ45 port.
KeithJust ordered the new Eversolo T8 which is a digital transport, a streamer/dac without the dac.
It looks pretty smart( expensive though £1200) and I am hoping it will be able to send a digital signal to my active speakers that already have DAC built in.
Thorbjørn’s Sarannas,Mantas and SBS, Dutch&Dutch etc.
It arrives tomorrow, Eversolo suggest pairing with their new Z10 dac available later this year.
Thanks, and yes, to your question. local files on my internal network i have ripped/stored on a nas/das.By ‘local files’ you mean music you have ripped/stored and not streamed?
It definitely shows album art used as ‘internal player’ and as Roon endpoint.
How better?I haven’t heard this sound better.View attachment 482430
I like those fine stings but the truth is, it was implementing "not better" than others, or, as good as others that sound the same (as to be expected).How better?
Not the digital side but the Saranna speakers they are very dynamic with real slam and punch.How better?
