You're right, I've been spinning it for 62 years and it looks really flat, but science says it's a ball, I'll have to investigate. ThanksYou guys must believe the earth is flat.
Troll member since 2025 and don't "get" the forum, blockedNot sure if serious or just trolling at this point
Knowledge begins with observation in a level matched quick switching environment.Yes an experimental error . You ca not "loose bass" on a pure digital input , this can not happen there is no plausible mechanism for this at all . You need DSP path to change the fr response . Faults in digital IO give rise to random errors , you can not attribute "analog language" to this ?
Perhaps, but only in the sound it makes when you pick it up and hit something with it. Or perhaps in the sound of the person being hit.Every digital cable sounds different.
- The digital signal is clocked differently between inputs, unlike USB
- The AES input can be processed by PEQ and the I2S is direct.
OK - then if you are using or not using PEQ, then the difference is not coming from the input but from the EQ. You would need to make sure EQ is off for everything if you want to compare differences between Digital interfaces.
None of your clock differences should be making any difference either - unless the DAC has malfunctioning clock recovery.
Without addressing that these devices are black boxes and for which there are limited measurements.From my post that @Mnyb was quoting from, which in turn was replying to your earlier post:
So both points have already been answered.
Which is significantly less problematic than taking those limitations in measurements, and using them to justify vanishingly unlikely** observations of differences based on uncontrolled listening comparisons. Or differences resulting from something different than what you are claiming (eg PEQ rather than input type - which is just a further lack of control.)Without addressing that these devices are black boxes and for which there are limited measurements.
- Rich
Fast switching, level matched but not controlled. Certainly more than most with this device, because for fast switching you need two... of eachWhich is significantly less problematic than taking those limitations in measurements, and using them to justify vanishingly unlikely** observations of differences based on uncontrolled listening comparisons. Or differences resulting from something different than what you are claiming (eg PEQ rather than input type - which is just a further lack of control.)
**(unlikely given the known engineering that goes into this class of device)
I've stated clearly what kind of evidence is acceptable - blind, well controlled.It seems obvious that no manner of comparison would be acceptable
which indicates a need to believe something without any real evidence or direct observations.
@seattlerocks Thank you very much for your detailed review. Since I am considering the Eversolo T8 or A6 for similar reasons, this is very valuable information for me.I bought a T8 and it arrived today, and I'd give it a mixed review so far. I was previously using a wiim, but wanted something closer to an android tablet so that I could change songs and settings without going to my phone so often. Wiim has spotify connect, but you can't easily start songs from the device itself, which is a pain. I don't want to have to track down my phone every time I want to play music. Overall thoughts -
The Good
+ The device itself looks great, they really made a good looking unit and I like it. It definitely looks the part.
+ The UI is also great. It's fast and responsive, the different album art and UV meter settings all look really nice. Doesn't make it sound any better, but it's a good experience and I like watching it.
The Bad
- The screen looks terrible at anything besides dead straight on. Straight on it's fine, but looking at it a few degrees off center, the colors are washed out and dim. Your average cheap cell phone off amazon has a better screen than this.
- The UI is clunky and difficult to use it a lot of places. I know I praised the UI just above this, but it's really hit or miss. Both on the device and on your phone. For example when setting up the device, I had to use a tiny on screen keyboard which was a pain to enter passwords on. You should be able to just use your phone to do all the setup instead. As another example, I just tried to open Spotify through the app, and I'm staring at a black screen in-app which I assume is a bug. It's not a great experience.
- The UI lags when using spotify and switching between songs. Take play/pause as an example - there's no immediate UI state change when you click the play/pause button, leaving you wondering if the click worked while you wait a few seconds. I'd instead expect the UI to update immediately and let you know the click worked, even if the actual music pause took a second. Similar for advancing to the next song. Parts of the UI like the song name update, and then after like 20 seconds the album art will load. Both of these should be better.
The Ugly
* To nobody's surprise, it doesn't sound any different than any of my other transports. We all know this going in, so it's totally fine. No music streamer is going to magically make your music sound better
I'm unsure if I'm going to keep it or not. The screen visual quality is the biggest thing bugging me right now, it really looks like an old TN panel. At ~$1,400 I'd expect more from a device.
Does whatever software you are using on the Pi work with the official display? If so, adding that display (pretty easy) May give you the convenient operation you want with an outlay of only about £70 (seven inch) or £50 (five inch) - (Uk prices including case and VAT)but rather a great display including convenient operation. If that is not the case, I will step back from the T8/A6 and stick with my RPi 4B.
www.audiosciencereview.com
@antcollinet I have a RPi4B with the 1st official 7"-display in another room with RoPieee running. But the possibilities are limited. "Pause" and "Play", that's it. And screen-resolution is quite poor (800 x 480 pixels).Does whatever software you are using on the Pi work with the official display? If so, adding that display (pretty easy) May give you the convenient operation you want with an outlay of only about £70 (seven inch) or £50 (five inch) - (Uk prices including case and VAT)
Brief description (with pictures) of my Touchscreen Pi based PicorePlayer streamer...
At the request of Adam, here: https://audiosciencereview.com/forum/index.php?threads/fan-less-silent-pc.41114/post-1487232 here is a short description of the Pi based streamer I built. Components: Raspberry PI 3b (Made redundant when I upgraded my media player to a PI4. Official power supply...www.audiosciencereview.com
A tablet in a dock might be another option, cheaper than fancy streamers, bigger display, you can put it wherever you want, and they have lots of other uses.@antcollinet I have a RPi4B with the 1st official 7"-display in another room with RoPieee running. But the possibilities are limited. "Pause" and "Play", that's it. And screen-resolution is quite poor (800 x 480 pixels).
Additionally I use a RPi4B with Roon-Web-Display (on TV) in the Livingroom. But as the Web-Display is more or less static, I don't like to run the big TV all the time. This is where I'd like to use something like Eversolo T8 or A6.
I also thought about a better RPi-Screen with higher resolution...
I've just noticed the pi display two when I looked it up for the prices in my first post. Resolution on that is 1280 by 720.@antcollinet I have a RPi4B with the 1st official 7"-display in another room with RoPieee running. But the possibilities are limited. "Pause" and "Play", that's it. And screen-resolution is quite poor (800 x 480 pixels).
Stand where you will.I've stated clearly what kind of evidence is acceptable - blind, well controlled.
So no, it is the opposite of this which is actually what you are doing in taking your listening impressions at face value without controlling for bias.
In the absence of properly derived evidence, the null hypothesis (no difference) stands.
No-one here will disagree with that, nor dispute with anyone the benefits they might find in such things.At the end of the day, if a device or tool improves your workflow and enjoyment, that has value too.
