Well. I am not sure what you mean. But it is a quote from the manual of DMP A6What’s their rationale? Do you have a source?
While it doesn't matter with the Eversolo,This is something that strikes me as avoidable though. Give both RCA and XLR their own output series resistors and there should be very little interaction aside from the potential effects of output loading in terms of opamp distortion performance (and even that shouldn't be much of an issue given that modern opamps should drive loads of 3 kOhms and up perfectly fine).
But alas - not without a cost then … looking forward to se what response Keith Will get from adressing this matter with the manufactorerEversolo already stated that both outputs can be used at the same time.
Hj Keith. No answer from Eversolo yet?I sincerely doubt there will be any cost, I will ask and post their reply.
Did you try adding the sub yet? I'm also interested in this.So still no definitive answer to this yet? I just got my A8 and was hoping to use the XLRs to feed my Bryston 4b and the RCAs to feed my SVS subwoofer but now I'm not so sure. I haven't introduced the sub into the system yet so looking for some solid advice.
Haven't added the sub yet but I think your suggestion about the lack of a sub out is quite valid. I do think that your idea about a high pass filter setting for the RCAs is a great idea and would be worth passing along to Eversolo. It might be able to be added via a firmware update.Did you try adding the sub yet? I'm also interested in this.
The other thing that I'm interested to know is if the Eversolo app allows you to set the high pass filter so that you can only send the low frequencies via the RCA and the high frequencies via the XLR?
I find it so bizarre that they didn't add a sub out to the gen 2s. The WiiM Ultra costs significantly less and has a sub out and a brilliant way of controlling the eq and hpf.
