Eversolo ME vs WIIM Pro+ digital toslink output into SMSL SU-10. Sound difference?
Mreservices
Will there be any sound difference on the digital side of an Eversolo Master Edition and a Wiim Pro Plus? They would be going into an smsl su-10 DAC via toslink. My understanding is there would be no difference but I wanted to confirm. The world of Dacs is all new to me. Typically I would just run this with a toss link into my Marantz av10 and be happy but I've wanted to try out different DAC systems to see if I noticed any music improvement. The reason I'm asking is I'm extremely unhappy with the whim application for Amazon music. It's extremely slow and cumbersome. The ever solo version is almost instantaneous and a much better user interface. It's worth spending the difference in the money in my opinion for the application. If there's no difference at all I may go to the lower A6 model instead of A6 master edition. I do appreciate your input and confirmation on my thought process.
With the exact same playback source : absolument not.
Thank you for your response. So I'm guessing that the same could be said between the two lower eversolo editions. I could just go with the standard edition and not the master edition. It's my understanding that the only difference is are the clocks and DAC. But if I'm using an external DAC and a digital output it shouldn't make a difference. Just want to confirm. Again, first time using an external deck so I'm just trying to make sure I am understanding everything properly. I appreciate the assistance.
Nor the analog output either. Eversolo DMP-A6 doesn't need an external DAC. The one integrated is already perfectly transparent enough for this purpose :
