Thank you! I wasn't sure what it was.You made me check to make sure I posted in the correct thread, I got an
Eversolo DMP-A8 Balanced Streamer/DAC
I got mine from Amazon.
So which is better? and A= athena ?I wouldn’t give much if any credence to AI.
The A* has an end to end analogue preamp with +10dB of gain.
The a8 has several dac filters you can adjust and a full eq and parametric eq so you can tweak the sound to your preference.
I don’t find anything at all lean about the a8. I have Harbeth 40.3xd speakers.
If you are looking for a Fatter / warmer sound try boosting the mid bass range a bit.H
Hello, which amp do you use?Hi,
How about using them "old fashioned" tone controls, at least in the good old days every half decent Amp had them,
yes you give up a bit on purity, but if it makes makes your music sound more desire-able, who cares.
But PEQ should be able to do the same i guess, i use both if needed, i'm just happy to have a good Amp with tone controls and a (variable) loudness function![]()
Only thing missing out on my unit is the door that hides the tone controls at the front, other than that it looks just shy of "mint" condition, some very faint scratches here and there but not on the front.Oh, it is very nice. Old Yammi.
Good look is important. But most important is good sound. Have fun.Only thing missing out on my unit is the door that hides the tone controls at the front, other than that it looks just shy of "mint" condition, some very faint scratches here and there but not on the front.
Hi,
Hi,
If the sound is thin, maybe it is because the Model 30. It is CLASS D. In my experience Class D sounds powerless. I had Lyngdor TDAI 3400 and than Hypex Nilai Monos. All thin. Now I own a Class AB Amp. Denon PMA 3000ne. Nevermore Class D for me.Appreciate the suggestions. I actually hadn't even considered using tone controls on the amp itself. I have a Marantz Model 30, with your basic tone controls...but that's definitely another avenue I can try when trying to dial in the specific "flavor" I'm going for.
As for speakers I've got MoFi V10's, so they shouldn't be contributing to the "lean" sound I was getting from the A8, but I could pay a bit more attention to the tweeter adjustability when I'm playing around with PEQ and such, too.
