Eversolo DMP-A8 Balanced Streamer/DAC Review
Rate this streamer/DAC/Preamp:
    Votes: 9 1.8%
    Votes: 12 2.5%
    Votes: 97 19.8%
    Votes: 371 75.9%
I am a new owner of A8 and I am very happy with the performance. It replaces my WiiM Ultra or Ultra + Topping E30 II (which is nice and cheap combo). I use it as streamer and DAC -> Integrated amplifier.
During my selection I tested number of DACs and streamers in my home environment.
To my ears A8 is not so harsh as A6 (I originally wanted to buy) and not as soft as Chord Qutest, Node Icon or Atoll MS120. It is also a clear upgrade vs. WiiM, despite being on an expensive side. The App is also slightly better than WiiM, which I like as well.
My conclusion is that "you get for what you paid", and to increase HiFi quality by 10-15% is quite expensive.
I read your comments with interest since I, too, upgraded to the A8 (from a Node 2i). While evey system will be impacted differently, I wouldn't say the A8 increased my system's sound quyality by 10-15%. Something more incremental perhaps? Maybe that's because I'm already using a Benchmark DAC. Putting its enhanced features aside, what I did find, much to my pleasure, is that updating the A8 proved to be seamless and caused no after-effects. That is a far cry from the Node 2i/BlueOS setup which was pain personified with every update -- the main reason I got rid of it.
Why does the loudness FIR filter of the DSP in the Eversolo DMP-A8 look so strange?
It appears that the Eversolo loudness FIR filter mimics the equal-loudness contour of the human hearing system. However, this is not something that should be directly “corrected.” What actually requires correction are the differences between loudness contour curves—for example, when a music recording is mixed at 80 dB SPL and later listened to at home at 60 dB SPL. In this case, the difference between the 80-phon and 60-phon equal-loudness contours defines the appropriate shape of a usable FIR filter (Toole et al., 2026).
According to the ISO 226:2003 equal-loudness contours, curves from 20 to 80 phons are very similar in shape above approximately 500 Hz, differing mainly by a constant offset in phon level. This implies that, above 500 Hz, a change of 10 phons corresponds to roughly a 10 dB change in sound pressure level. Consequently, no correction is required at frequencies above 500 Hz to preserve tonal balance (Toole et al., 2026).
In contrast, below 500 Hz the equal-loudness contours converge in an SPL-versus-frequency plot. As a result, when listening at home at a lower SPL than the level used during mixing in a control room, the bass frequencies below 500 Hz must be boosted to maintain perceived loudness balance (Toole et al., 2026).
Therefore, it would be highly desirable to have access to the FIR parameters of the Eversolo DMP-A8 loudness function, such that its effect automatically decreases as playback volume increases, transitioning smoothly from low to higher listening levels.
Furthermore, as suggested by Toole et al. (2026), easily adjustable bass, treble, and tilt controls—implemented via virtual knobs or sliders—would be highly recommended.
Any thoughts on this?
Reference
Toole, F. E., Olive, S., & Welti, T. (2026). Sound Reproduction: The Acoustics and Psychoacoustics of Loudspeakers, Rooms and Headphones (4th ed.). Routledge, Taylor & Francis Group, New York and London.
I agree. Major reason for my upgrade to A8 was upgrade of DAC. And to my ears AKM DAC of A8 sounds great. The streamer functions are comparable to WiiM, which I still use in my second system.
ok, just stumbled on to the ASR forum through this post coming up after an exhaustive internet search. I have a few big decisions coming up this week and it seems appropriate to post here (please advise otherwise).
My question is this - Is the Eversolo DMP A6 or A8 appropriate to use as your ONLY preamp? I have an older PS Audio 200 power amp that I connected to a Gen2 master edition a6. and its been great, coming off a 20 year hiatus from the hobby. However after a few weeks I noticed two things -
1. It seemed like I was wanting a bit warmer sound.
2. The Power output seemed like it was being limited by the preamp.
So I after some more hours online I ordered the A8 because reviewers mentioned warmer sound (KTM) and better preamp. Now I am reading this post and am more confused than when I started 80 hours of online reading ago.
1. Is the consensus that you need a preamp or integrated amp for best use of the Eversolo? vs dmpA8 (preamp) straight to power amp?
Final thoughts to share. The A8 is backordered so I could easily still cancel.
Your feedback/suggestions/guidance is welcome. Or if I need to post somewhere else please advise (I just joined ASR today).
my options for Integrated if this is the route that becomes clear/suggested. considerations - Large livingroom and Dali Oberon 9
Parasound Hint6
Rotel 1592
Rogue Audio Pharaoh
Firstly there will be no difference in SQ between any of the Eversolo streamers see Amir’s measurements on this site, the A8 adds analogue input so may be useful.
You don’t need another ‘preamp’, streamer straight to power amplifiers is fine.
No sub out on the eversolo.
Hi let say you connect the eversolo streamer to a ma352 mcintosh amp. The ma352 have 2 subs out I think. So do you connect the 2 svs sb2000pro subs to the ma352 sub outs? The SVS sb 2000pro sub have inbuilt dsp.
My God. Stop spreading this nonsense. The A8 has a preamplifier. Yes. But this preamplifier doesn't amplify. It's a passive preamplifier. That's not what you expect from a preamplifier. So it's misleading. The statement that a preamplifier is included only leads to disappointment. Eversolo isn't doing itself any favors.
A8 is for those that need analogue input to output ... without any digital processing, so no EQ or anything else. Aimed to audiophools...
Have to say some condescending commentators now regulars on ASR make statements like above. So any owner of an A8 can choose to do what he likes with it.
There is digital processing and EQ. Why would you choose to call them an audiophool!!!
This derogative comment is meant for subjective views hardly the territory of all Eversolo A8 owners.
Interesting. So you do have an A8 with ADC, that would be necessary to EQ via digital processing the analog signal?
Which online radio services does it provide?
Edit: Additionally, the software installed on the device or the downloadable app list is country specific? Or all come with the same apps?
Thank you for your replies.
I’m having a preamp concern with my brand new A8. All settings are proper as far as I can tell. I have tried 3 different power amps (one stereo and a pair of monos). The issue is when going from -32 to -31.5 (0.5db steps) or from -32 to -31 (1db steps) there is a HUGE increase in volume. It is perceived as far more than 3x as loud as the previous step. Is this normal or does this possibly indicate a failure in the volume relay? Is there a distinct non-linear or logarithmic volume increase when you reach this level? I’m not seeing any other mentions of this so it seems very abnormal to me.
Replay gain is off. No DSP. Streaming Roon and eARC input. Version 1.4.76 and it will not fetch any new update.
Edit: With a basic SPL meter I played a DSF file of 500hz. At volume level -32 is is 65db with both channels playing. Volume level -31.5 is 79dbA!!!! I also tested left and right channels separately. The left channel behaves normally. The right channel has failed and is the source of the massive volume discrepancy.
It goes without saying I am very disappointed. My buddy had a DMP-A6 fail, let the magic smoke out, and blow a fuse on his power amp. Now this. I’ll be returning the Eversolo and finding something else.
Wait a minute, am I right in thinking the A8 does not have a subwoofer output that can be DSPd? As in do room correction and delay separately from the front speakers? Everywhere I hear you can attach a subwoofer and that it has great PEQ capabilities, but this would be very bad. Every cheap DAC/streamer can do it, but this thing can't? What were they thinking?
Correct. The A6 only has two DAC channels.
You can output via XLR and RCA simultaneously, but they will always carry the same signal.
If you want an independent LFE signal which can be DSPed separately from L/R, then you need a device with three or more DAC channels, like for example the WiiM Ultra.
Great. Why can't there be one proper device? I am looking for an upgrade over my MiniDSP Flex HT + Wiim Mini combo when using stereo (the MiniDSP will remain for surround), a Wiim Ultra just won't cut it. The A8 was perfect with the analog pre-amp etc., but then they mess up on one of the most important features, bass management. I also don't understand why no one seems to be bothered by this. The A10 does have the feature, but it's double the price for a surround DAC...
I just got one of these, what a sweet device for Apple Music users wanting to cut the cord with a nice (almost) full size chassis. I have a 1tb SSD showing up tomorrow and I can throw my old 1tb hard drive attached to my Mac in the same box as the Topping D10s. Being a sucker for meters and pretty displays made it a no brainer for me. I use coax out into a Denon 4800 with Dirac ART so I’m wasting quite a bit of the A8 selling points, this was worth enough for me :-)
Please: What (specifically) is it called and where do you get one?
