Maybe also make a screen recording?No, the problem exists when using the app - not when using the touchscreen
I had this exact same problem and noticed this a couple of days ago , have my music files on a Synology NAS that I access via the Ever Solo app on my iPhone.Please can someone test this out and check this is not just happening to me?
Using the A6 touchscreen, when I press the "back arrow" to back out of an artist's albums, I am returned to that same artist folder. Excellent!! However;
when using the EverSolo app, when I press the same "back arrow" to back out of an artist's albums, I am returned straight back to the beginning of my music library. This means constantly scrolling from the beginning of my library to listen to each and every artist.
(Music library on external HDD via USB)
Much appreciated
Zip the file and attach , should workYes, have a screen recording but the forum does not allow the file extension to be attached!
make a .zip or send to service#eversolo.com.Yes, have a screen recording but the forum does not allow the file extension to be attached!
Sorry for taking resources from this thread.@AdamG247
Hi all,For issue feedback, please contact service#eversolo.com directly
Email sent to service. Apologies also to threadmake a .zip or send to service#eversolo.com.
Got it,Email sent to service. Apologies also to thread
We reproduced it and will solve it in the next versionThe device is a IPhone 14 Pro Max with IOS Version 16.5.1.
I have now made a screen recording of the issue , please see attached.
Thanks, any thoughts on the delay between tracks whilst streaming via Qobuz? ... as this is a nagging issue that needs a resolution as well!We reproduced it and will solve it in the next version
How?That's IR. You have to pair it to use it with BT.
Did you do it within a foot of the A6 ? "Point it within 30cm and long press "Play" and "Vol -" at the same time till indicators light blinking to finish pairing." - also a note from one of the dealers mentioned checking to make sure the bluetooth antenna was properly installed.How?
For what it's worth, yesterday I tried all of the Zidoo device codes currently in the Sofabaton database in an attempt to find Power toggle. None of the Zidoo codes worked. I ended up ordering a remote with the intent of learning the codes into Pronto, JP1, and Sofabaton formats ...What IR codes does Zidoo/Eversolo use?
Is there something already existing in Logitech Remote database that we can use to perform basic controls? I will use phone app for everything but the IR remote for 4 functions only: stop, playback, previous, next track.
