quick question, is it possible to use the analog out and digital out at the same time? i want to connect the streamer to active speakers and use the analog out to connect a subwoofer. Thanks!
I guess i am dense but i have no confidence i know what this meansNote: from the manual
* all digital input connections only support output audio by analogue output, not digital output’,
I didn’t try this but when our next order arrives ( hopefully soon) I will.
Yes, i think it was last week is when i read of the updatedidn't Eversolo also recently update firmware?
where did you order from?Just ordered the standard edition. ETA 21 June. Hopeful to replace my current streamer as a transport. Cheers
Ordered from my local seller in Singapore. He told me the next batch will arrive around 21 June.where did you order from?
thank you, I have the same question but I'm only concerned about whether both digital and analog outputs can work simultaneously when using streaming, NOT using any of the inputs.I guess i am dense but i have no confidence i know what this means
I asked this of eversolo but no response.
My take ...
Not including streaming, if you use any digital input (coax, optical or usb-c), they only will provide analog output. It cannot be passed through to digital out. The only digital out comes from streaming
I still dont know if you can use both analog out and digital out simultaneously and was wondering this too. I believe, through a few interpretations from zidoo thread responses, the answer is no, you cannot. But dont listen to me, wait for confirmation from someone with the device in hand (I wont have mine until July)
The app only allows the selection of one output at a time other than xlr/rca.thank you, I have the same question but I'm only concerned about whether both digital and analog outputs can work simultaneously when using streaming, NOT using any of the inputs.
If you have get the answer, I'm really interested thanks![]()
so if I understand correctly, I could use coax out AND analog out RCA at the same time, right?The app only allows the selection of one output at a time other than xlr/rca.
No. The attached screenshot of the port selection options may help.so if I understand correctly, I could use coax out AND analog out RCA at the same time, right?
indeed, thank you. Unfortunately not what i was hoping forNo. The attached screenshot of the port selection options may help.
Yes, it comes with 4GB standard to start, easy access door on the bottom of the unit to swap out M.2 NVMe SSD drives, max capacity 4TB. You may find the Zidoo/Eversolo forum on recommended SSD's helpful - http://forum.zidoo.tv/index.php?threads/recommended-ssd-drives.95672/If I am not misunderstood, there is an internal drive.
Does the drive come standard ?
If so, what is the standard storage for the included drive ?
If I want to change the drive to increase storage can it be done easily ?
Just turn the TV off (or don't turn it on in the first place) or change the TV input to antenna or use one of the TV's apps. You may have to turn CEC off to prevent it from interfering (like automatically turning your TV on even though you just want to listen to music on the A6).I have my DMP A6 connected via HDMI to my Marantz SR8015 and on the TV it’s a blue screen. Is there a way I can avoid this? Like to show what’s playing or even see a TV channel?
Non. La capture d'écran ci-jointe des options de sélection de port peut vous aider.
I confirm at Rose the same, you can only select one output at a time, either analog or digital....No. The attached screenshot of the port selection options may help.
