Nutul
It is up to 192, not trespass it with, say, 384
Thank you for your reply.It is up to 192, not trespass it with, say, 384
Not if you are using the digital outsWonder is there is a sound quality difference between the A6/A6 Master/ and A8.
I wouldn´t damage my already fantastically working and sounding Mki by spending money on such an "upgrade".And if a better power supply is added?
BEATECHNIK X LHY AUDIO LPS-A6-MKII Linear Power Supply Module for EverSolo DMP-A6 Gen 2
Designed specifically for the Eversolo DMP-A6 GEN2, the LHY Audio LPS-A6 MKII linear power supply stands out thanks to its high-end architecture.www.audiophonics.fr
The only change will be the amount of money in your bank account.And if a better power supply is added?
There were some reliability issues with the linear power supplies of the initial batch of Gen 2s. Do you know if Zidoo has resolved those problems in newer units?The only change will be the amount of money in your bank account.
Good to know; thanks, Keith.I believe they have sorted out the problem, I haven't heard any recent reports of PS failure.
There is no new update in that site since v1.5.62, and they already released 2 new updates.You can always look at McBluna site; the guy keeps everything up-to-date as soon as things get available.
He doesn't keep betas... I think the .75 is in the air...There is no new update in that site since v1.5.62, and they already released 2 new updates.
forum.zidoo.tv
