Nutul
So, check in the EQ settings if, perhaps, there is a flat profile active and the output gain is - again, perhaps... - set to something in the lines of -5 or -6dB (which roughly means halving the volume, you may agree...)sorry - work life gets in the way with my new setup! Yes, exactly this - if I toggle the passthrough switch between on and off (where when 'off', the volume is maxed out) the passthrough volume is about twice that as it being off - it's substantial. Granted, I'm not hugely knowledgeable in the hifi arena, but I'm pretty good at gain-staging with music gear (synths/drum machines etc), so perhaps I'm taking bad habit across with me. But yes - I'd assume that the passthrough and the full volume in the normal setting to be largely the same - this isn't the case.
Any help would be much appreciated!
I think the outputs (and the inputs, IIRC) have independent volume memory, but sometimes get fooled... try to switch input, and return back to the current; and/or do the same with the output.
ETA
Also, I remember hearing about different levels on the RCA outs, depending on whether the output selected was only RCA vs RCA and XLR together. Play with that as well.
Just my 2c.
Cheers, Al.
