Actually, I am not disappointed at all.Very disppointing given the functionality of the Wiims and Bluenodes and nothing to tempt me to trade up from the std. generation 1 (like the trigger though and the silver finish)
You are not alone.Eversolo's website seems to be down. Is anyone else encountering this or could it be just my browser? Wanted to see what they have posted for the DMP-A6 Master Edition thus far.
Is it possible to play SACD .iso files from UPNP server, for example Servioo on PC ?I have not tried cue files, but SACD .iso is my main use and it works FLAWLESSLY in 2/6 channels. The internal library search an index disks and tracks without problems.
Don't think you would be disppointed, particulary at that priceMany new models announced, but I'm still thinking - is it worth to get that A6 for 400€? I guess at that price there's not so many options?
2. Can anyone give some feedback on how well the Eversolo internal library function works with a modest sized library of music stored on the network? It looks like Eversolo have been improving the app and library function over time, so I am wondering how well it works now (speed of browsing, layout, etc). I am hoping not to have to run a upnp server on my network and to just use the Eversolo unit, but I don’t know if the Eversolo will be up to that.
3. Can anyone compare the internal library function of the Eversolo and Wiim units? I currently have Sonos units in a couple of other rooms I will be looking to replace and these will probably either be Wiim Ultra’s or second hand DMP A6s. I am leaning toward the latter even though it will be more costly, but it depends on how well the internal library function works or if I have to end up running a server.
Is there a point to search for ME instead of regular A6? Approx ~300€ more expensive.Don't think you would be disppointed, particulary at that price
www.puriteaudio.co.uk
if Gold is more liked than Silver on the Emblem go for ME.Is there a point to search for ME instead of regular A6? Approx ~300€ more expensive.
sorry - work life gets in the way with my new setup! Yes, exactly this - if I toggle the passthrough switch between on and off (where when 'off', the volume is maxed out) the passthrough volume is about twice that as it being off - it's substantial. Granted, I'm not hugely knowledgeable in the hifi arena, but I'm pretty good at gain-staging with music gear (synths/drum machines etc), so perhaps I'm taking bad habit across with me. But yes - I'd assume that the passthrough and the full volume in the normal setting to be largely the same - this isn't the case.@Purité Audio
Keith, he's saying that with volume bypass set to OFF, and then turning the volume wheel to the max, the volume heard is way too low, compared to what it was with the volume bypass ON. (the pre and the amp are the same, as well as their volume level, of course)
TBH I would expect that volume bypass ON would lead to an output level equal to the volume obtained turning it up to 0dB with volume bypass OFF (wouldn't it?)... it appears not to be the case, though.
