Eversolo DMP-A6 Streamer Review
Rate this streamer/DAC:
    Votes: 7 1.1%
    Votes: 31 5.0%
    Votes: 162 26.1%
    Votes: 421 67.8%
De ce nu iese 24/192 pe ieșirea coaxială când sunt pe muzică Apple. Ce setari ar trebui facute?
I think you should select COAX as the output; but I think this applies only if the player is the A6 itself, not any app on the phone.
Can you clarify what is your scenario? (and write in English, so that we do not have to jump to and from Google translate, thans)
Done, with the latest update V 1.2.30, it bypasses the Android system on Apple music, 24/192 on the coaxial output read with a DAC Topping DX7PRO.
When I put a DAC on the coaxial output, before the update I had 16/44.1 all the time regardless of the album. Now it is OK.
Sorry, but I put the English translation on the website, why is it displayed in Romanian I really don't know, probably I'm with Google all the time on the Romanian conversion?
Sorry for the moderator, now I understand why the posts were deleted.
Happy to hear everything is fine.
For the translation... I think, when you ask Google to translate a site, you see everything translated (the conversations too) and you have the feeling that the site is indeed in your language...
La revedere ;-)
I have the same setup and i prefer below, but it needs manual switching in C298 to select RCA/XLR and A6 volume passthrough switching.
My setup is NADC298 used for front 2 channel amplification from cinema50 external preout.
Mostly for music, i use direct (no room correction softwares) , so from Eversolo XLR out to C298 XLR IN . In this case you need to switch the 2 dip switches in back of C298 to XLR input. This is really great for direct music listening and my favourite for music.
To hear music through DIRAC+subwoofers (from cinema50) , i have also connected the Eversolo RCA out to cinema50 RCA IN.
While watching movies or sometimes music with some coloring and subwoofer, i use RCA from cinema50 to C298, here you have to select the 2 dipswitch to RCA.
There are 2 caveat's here. First is manually switching the dip switches in C298 to select XLR/RCA and second is you need to switch back & forth the volume passthrough in A6 when you are playing through marantz , but for me it works , but wont work for many :) .
Caution - remember to set the volume limit start up to -40 in A6 to accidentally protect your speakers, if you forgot to switch the volume passthrough off while playing directly from A6 to C298. With proper saftey settings in A6(start up volume limit function) , it is safer even if you forgot to switch the volume passthrough in A6 and i tested it as well.
This procedure is bit complicated, but its safer and you can use DAC from A6 to both cinema50 & C298.
This works for me as i only see movies in weekend , so 80% of time music .
You could also use HDMI out from A6 to cinema50, but then A6 DAC is better compared to Cinema50.
Thanks again for your input! The sound coming out of the A6 is far superior. Listening to Radiohead's "Numbers" and "Glass Eyes" and Nora Jones "One Flight Down" sounds incredible! The Cinema 50 sounds like the vocalist are wearing a mask. The A6 is that much better.
Greetings. I tried to recognize some differences in the sound between the built in DAC in Eversolo and my external RME ADI 2 DAC, which I use as a headphone amplifier. While switching these two DACs, I heard no difference in the quality of the reproduction between Eversolo DAC and RME ADI.
No I haven’t heard any differences, but then if you look at the impeccable measurements of both devices you wouldn’t expect there to be.
That is true! I appreciate RME due to headphone amp and some PEQ features if needed.
Just came here to thank you as well for this tip. I connected the XLR Cables from my Eversolo DMP-A6 Master Edition to my Yamaha Av Receiver with Pure Direct mode enabled on 2 Channel stereo. Uau! What a sound! Really impressed! Far superior compared with HDMI Output. Listening to Pink Floyd Dark Side of the Moon (50th Anniversary remastered 2023) which is MAX-FLAC 192 KHZ 24 bit on Tidal, is out of this world!..... Maybe from the moon :) So much detail on sound!
Thanks Werther 44210.
Can any other users comment on whether they have successfully used a CD drive for playback?
Thanks in advance.
I have a cheap Samsung USB dvd drive plugged into my A6. It is able to play the CDs I have tried. It will also rip most CDs to an internal SSD. The exception appears to be CDs from Sony (probably have copy protection crap) and a few others. Besides that, the service that it uses to get CD art and song names does not recognize quite a few CDs. Some CDs it gets the correct song information but doesn't get the CD art so it just displays a blue or yellow colored picture of a CD. Others it doesn't get the song information at all.
There may be a way to change the source it uses for getting CD information. So far no luck in finding a way to do that.
What is the purpose of a local CD-drive?
Why don't rip at a PC/Laptop with USB-drive and copy to NVME in A6 or to NAS?
If ripping worked on all CDs, the reason would be convenience. Since it doesn't work for all CDs currently, you are still better off ripping them on a PC. That said, I was replying to a question about being able to play back on a CD player connected to the A6.
I've ripped all my CDs, even those Bluenote ones with so called copy protection, using EAC.
No issues.
I want on a few other forums and it seems like other people are having the same Qubuz dropouts starting a few weeks ago and it looks like others are having the same problem. My Wifi is really strong and I have fiber so I know it’s not a wifi issue. Plus Apple Music streams fine.
Is it a stretch to say I would buy the DMP-A6 just for the streamer? I use an external DAC, but is the Eversolo as a streamer worth the money, or are there alternatives? The implementation of Apple Music is tempting, because that's what my wife uses. I use Qobuz. Sometimes you read about problems with streaming services such as Qobuz, with the DMP-A6
If you just require a streamer then the Wiim ‘pro’ is easily good enough, if you weren’t using an external dac then the Wiim pro ‘plus’ is easily good enough.
So it really isn’t a question of sound quality but of features ease of use, pride of ownership, aesthetics etc.
I se Quboz here with the A-6 and A-8 and haven’t experienced any issues.
Dear All:
i am still confused after doing so much reading here on this long thread.
i have a multiple speaker set up with the fronts being golden ears. i am currently using the Node X feeding into an Anthem AVR using ONLY Tidal high res.
i am curious about getting an Apple TV 4K for a mere $150 to see how Tidal's Atmos tracks sound. also, as i listen to 50% pop/rock and 50% classical, i am interested in Apple Music AND Apple Music CLASSICAL (due to Apple's acquisition of Primephonic). BUT, buying an Apple TV 4K merely allows me to get non-high res streaming via Apple Music/Apple Music Classical as it tops out at 48kHz.
Question: if i were to buy the A6 Master Edition and plug in an ethernet cable, would i be able to stream Apple Music AND Apple Music Classical at HIGHER RES than merely 48kHz immediately? would there be a lot of software/firmware jerry-rigging involved? i do not wish to "side load" or do anything that is not fully supported by Eversolo. i prefer to have everything supported and a legitimate function of the Eversolo A6 product.
may i please ask if a kind person would please summarize to see if the above is possible? thank you so much in advance.
Dear All:
As I understand, the A6 won't be able to forward the Dolby Atmos tracks to your AVR... I don't even think it will be able to play them locally downmixed to stereo...
@Nutul et al:
thank you kindly for your reply.
OK, so the A6 cannot and doesn't handle anything to do with more than 2 channels and is strictly for 2-channel music. fine.
the the follow up question would be:
can the A6 immediately out of the box be able to stream Apple Music AND Apple Music Classical in full resolution? or would A6 streaming Apple Music/Apple Music Classical be also limited to 48kHz please?
it is not clear to me that when one gets the A6 or the A6 Master Edition, that we can take it out of the box, connect it in the back with an ethernet cable, be able to stream Apple Music/Apple Music Classical at MORE than 48kHz, meaning that the A6 would perform FAR better than what an Apple TV 4K can do in streaming high resolution music from Apple Music. buying an Apple TV 4K will only allow one to stream at 48kHz, and if i were to buy the A6, i'd like to know for certain that it can indeed stream Apple Music at full high resolution. i just don't get that feeling by reading this long thread yet.
thank you all in advance.
