Without the mid/side processed type of XTC, which I suggest, I can't see how the cancellation can be fully effective for center-panned sound objects without introducing the sensation of being "deaf to the opposite ear" for hard-panned sound objects.
I do not know what you mean by “fully effective“. For me this kind of argument creates dichotomies out of nothing.
With i.e.10dB of crosstalk attenuation the amplitude form the opposite speaker is only 30% of what it is in stereo. That will already reduce the interference effects considerably. And it will not create problems of feeling deaf, unless you do it in the bass with a recording that has panned bass.
I want to add, that there is a price to be paid for the compromise, I was talking about earlier.
The sound engineer in the studio (stereo speaker arrangement) who puts a (vocal) tracks in the soundstage will make these tracks sound as good as possible with all the tools and experience at hand.
Attenuating the crosstalk will not only “clear up“ the interference, it will change the sound. Both the timbre by reducing the 2kHz comb filter dip of tracks in the centre and the soundstage by moving the positions of off-centre tracks.
Some of these effects might be unwanted.
But if the XTC is reduced enough not to introduce that problem to the hard-panned sound, I can't see how the XTC can be effective enough to make an audible difference for the center-panned sound objects either.
Well, it does make an easily audible difference with many recordings for me.
I think that for any XTC program to fully succeed, it should never need different settings for different recordings.
I am not into the business of promoting some program to “fully“ (again) succeed. But if I were, I would think that it certainly depends on the complexity of the settings.
Recordings differ that much, that all kinds of adaptions are needed on a certain level.
Everybody uses a volume control after all, and tone controls or switching to multichannel are common too, so a knob to adjust crosstalk should not be too much to handle. (And there is always the “off“ option.)
OTOH, most music is listened to over headphones nowadays, and hardly anybody uses any kind of crossfeed or HRTF-base solution as the OP is presenting.
That's why I suggest an XTC program with either hard-set mid/side processing or a gradual decline toward the stereo field's extremes as a "one-size-fits-all" solution, a solution that should work well for both pure stereo recordings and multi-mono mixes containing hard-panned sound objects.
One could do all kinds of things, but this introduces even more processing and you would lose the soundstage extension and the extra spaciousness that comes with the reduced crosstalk at the borders of the soundstage.
The problem is that with a stereo speaker pair in a regular listening room you will get the worst of both worlds:
- because of the speaker crosstalk, you will not get the soundstage from the record (if there is any)
You will get the soundstage from the record, there is no other. But you will get the stereo version of the soundstage, at least as far as the room allows. This probably a bit similar to what the sound engineer heard, but some people will prefer the XTC version nevertheless.
I do agree about the listening room problem.
