human ears and brain are much more sensitive than any measuring equipment currently available
Ok I’m out.
do you mean least count of analyzers is not improving with time ? what they could not measure few years back now these can measure it. i think this is enough of hint for you.
Ok I’m out.
No, except for S/N ratio there is no point in improving THD performance beyond a person's personal threshold.you mean there is no point of better measurements after a certain limit ?
human ears and brain are much more sensitive than any measuring equipment currently available.
Glad you arrived to a "sound" conclusion by yourself...you mean there is no point of better measurements after a certain limit ?
Ah . . .you mean there is no need of improvement to sinad by new technology in the coming years ? human ears and brain are much more sensitive than any measuring equipment currently available. but brain need to be trained and it should free from biases like r2r dacs are better, good measurements sound clinical and blah blah.
Exactly that's what I wanted to say. If there is no effect of numbers beyond a certain limit then are people spending $17500 just to show off or for the looks or for the heavy metal extruded chassis or for that silver facia with sexy volume knob or for fancy tech named ring dac which is of no use or for blah blah or just for the heck of it can't believe upto what extent people have been brainwashed by DCS that people don't want to listen anything negative about it. Don't you people ever see the 5 figure price ? Or like your ears your eyes have also lost the ability to discern things ?Glad you arrived to a "sound" conclusion by yourself...
you can google about bartok being bright and you would find a number of threads for same. also check headfi fb post by golden sound for bartok measurement where a member commented about bright sound of bartok.
Do you have any idea how quiet -110 db is?why not ? if odd harmonics "dominate over even harmonics" then timbre is affected negatively even if at -110db.
Wait, you guys don't get annoyed by a dog barking 200km's away?Do you have any idea how quiet -110 db is?
D10BALANCED ? Don't know, I just have the Topping, not the dCS.I don't want to jump into the usual audibility threshold dissension.
I am just curious, the Bartok being too bright compared to WHAT?
Yep.you mean there is no point of better measurements after a certain limit ?
No, there really isn't. Only for vanity's sake.you mean there is no need of improvement to sinad by new technology in the coming years ?
It is like 6 microvolts if your DAC puts out a 2 volt max signal.Do you have any idea how quiet -110 db is?
Somehow that wasn't the first question that popped into my mind. So what is the answer?What's the largest life form you can kill with 6 microvolts?
Depends on the amperage. You might be able to anger some mitochondria.Somehow that wasn't the first question that popped into my mind. So what is the answer?
You mean all dacs having a sinad of around 109db (Bartok measured around 109db sinad ) should sound same ? If that so then why one should buy this $17500 dac ?Yep.
