mikeylemur
- Joined
- Jul 15, 2025
- Messages
- 13
- Likes
- 4
I’m currently looking for a new set of computer speakers to replace my old Q Acoustics 2010i’s, with a budget of under £110 on the used market. I really liked the tone of the 2010i’s, but they were just too bulky for my desk setup. This time, I’m aiming for something more compact—ideally under 230mm in height.
One of my biggest issues with the 2010i’s was how much the sound changed when I moved around. Even a slight shift in head position would throw off the balance between channels and break the immersion. I’m guessing that’s a side effect of nearfield listening, but I’m wondering if there are speakers out there that handle this better—maybe ones with wider dispersion or more consistent off-axis performance.
After digging through some forums and checking out measurements, I’ve narrowed it down to afew models that seem promising and are readily available used.
Single Pair (Without Subwoofer)
Would the iLouds offer a noticeable improvement over the MR3s, or would the difference be so minor that I'd be better off just adding a budget subwoofer?
Alternatives I’m Interested In (But Hard to Find or Lack Measurements)
- iLoud Micro Monitor - iLoud Micro Monitors measurements and quasi-anechoic spinorama | Audio Science Review (ASR) Forum
- Edifier MR3 / MR4 Curious if the rumored MR4 revision makes it a meaningful upgrade over the MR3. https://www.audiosciencereview.com/...ments-its-probably-been-upgraded.42941/page-6
- Cambridge Audio Minx Min22 (Balanced Mode Radiator) https://www.audiosciencereview.com/...ding-with-weeb-labs.21131/page-6#post-2352324
- KEF HTS3001 (Coaxial) https://web.archive.org/web/20131011122538im_/http://medleysmusings.com/wp-content/uploads/2013/01/Kef-HTS3001SE-Speaker-Sealed-0-30-60.png
- Fostex PM0.3 https://www.audiosciencereview.com/forum/index.php?threads/fostex-pm-03-active-speaker-review.12517/ Amir seemed to think these were okay.
- JBL Nano K3
- Pioneer DM-40
- Fluid F4
- EVE SC203 Also out of budget, but how does it stack up against the iLoud?
