watchnerd
I got a free pair of those from Burson and reviewed them for head fi.
What I am curious about though is that "hum" is there any concrete is measuring how much of it a cable resists? We saw how being near certain components introduced a LOT of hum and being moved away from such components removed said introduced hum. Are the cables in existence that can and do block the introduction of this hum when near said components?
We are talking about cables transmitting analogue signals here?
What about cables that transmit digital signals, like usb cables, coax/AES/EUB, I2s etc.... ?
The idea has been fed that balanced gear requires twice the components and is inherently unmatchable. So quality single ended circuits are inherently better, more musical, and closer to theoretical perfection (no matter how much noise they pick up). Yes I know the various things wrong with the idea, but that is the idea nurtured in some high end circles.Fully balanced cables are the usual better option for reducing interference.
Which is also ironic....if audiophile vendors wanted to make "better" cables, if only from a noise rejection POV, they should have switched balanced decades ago.
Why they didn't, I don't know....
AES/EBU, and USB are balanced.We are talking about cables transmitting analogue signals here?
There is no such thing as "digital signals"; all digital interconnects transmit analog signals that *represent* digital data.
So, given the same digital source data, you should be able to compare two cables using an analog null system.
I like to use a calibrated microphone, one loudspeaker of a stereo pair playing, and compare reproduction using null software. The location of the speaker and microphone remain static during the test.
The advantages are:
Relatively simple measurement equipment required
The entire system is measured from source to speaker & room, which takes care of how the DUT affects other components (if it does).
After dealing with the crap the believers deal out, day after day, year after year, it's no wonder he sometime behaves in the manner he does. I've encouraged him to be more active here at ASR, he's a greatly valued member of the scientific audio community.Umm, when one clearly sets themselves apart as a antagonist you can expect a reaction. In this regard Winer often clips his own wings with a unnecessarily belligerent attitude at times which is a real shame as he’s done a great service to the hobby imo and continues to do so as well as being quite amusing at times.
A J Southfield deserves a gold star for his sparky tongue.Bah, he's a rank amateur, now Peter Aczel in his prime, there was a guy who really could antagonise when the mood took him!
Like all analog cables, if the LCR combine with the source or load impedance to alter response, that can be easily measured and determined.I do think Headphone cables make an impact
Firstly I don't agree that there are no digital signals they are all analog. The analog quality can be horribly degraded and work as a digital transmission.
A null test of digital signal cables would work, but unlike analog audio cables, the bandwidth would need to be well into the megahertz region. Further you could have digital cables that will not null at all well. While the digitally retrieved signal fed into a DAC could put out near theoretically perfect results with both resulting analog reconstructions within the limits of thermal noise.
While using a microphone and the whole system over a speaker can have its uses (Ray does this often) it has its limits as well. Ambient noise various background sounds not being constant (passing traffic, fridges, HVAC) and keeping everything placed exactly even when you don't move anything will mean a null possible here is much less good than will be possible for signals leading up to the speaker. If you wish to null the whole system, the most precise way would be using the signal at the speaker connectors. Any change here would be seen and will be reproduced by the speakers even when it is far too small to be detected as sound in the room.
Time and frequency domains are mirror images.So we know differences between cables in frequency domain are insignificant. How about in time domain?
Everything digital occours completely in the analog domain. Even the CPU in a computer does it's processing via capacitors, resistors, and transistors. Early digital data was stored on vinyl records, and recovered via a phono cartridge. You must grasp the concept that digital data and digital storage, processing and transmission are different things. There is digital diata but in every case require analog representations of the digital data to manipulate, store, or transmit said data.
What happen if we start producing some active cables, with some kind of mild amplification into it?
You can resolve any such question these days by sending the information to one of the anti-fake news fact-checking services.Yes, digital signals in real world applications are represented by some analog value but are not the same as an analog signal value.
