From what I can tell there is compensation needed for the THG Hump that comes before the actual DAC chip. If we look at the what Benchmark has laid out on their site you can see the block diagram:
https://benchmarkmedia.com/blogs/application_notes/dac3-introducing-the-new-es9028pro-converter
As you can see after the Over Sampling phase they run the signal into a Channel Map and THD Compensation routine. All of this happen before the chip. I'm not sure exactly what Benchmark does, but could it be some sort of balanced differential signal so the THD subtracts instead of adds?
