Still 9038q2m? That will be really interesting. Be sure to use the two test files as well.I should be getting the first DAC with ESS hump fixed in a couple of weeks.....
First generation 9018s has a different problem from 9038q2m. 9018s has noise floor modulation but doesn't cause serious imd and thd. The newer generations don't have noise floor modulation, but can cause extra imd thd easily.If I remember correctly, topping dx5 and dx7 were with and without hump ESS based DACs?
Correct. That is when I first discovered the regression in intermodulation distortion.If I remember correctly, topping dx5 and dx7 were with and without hump ESS based DACs?
I guess non pro versions?But you didn't make any mention of any ESS hump in this review?
https://www.audiosciencereview.com/...matrix-audio-element-x-dac-streamer-amp.7782/
You said: "Intermodulation distortion is likewise excellent"
It has 9038Pro. It has the slightest hint of 'hump' but it is so reduced you wouldn't use it as an example of the 'problem' for sure.But you didn't make any mention of any ESS hump in this review?
Yes, I think he means an ESS DAC with a 'revision'.Maybe, all he said was "I should be getting the first DAC with ESS hump fixed in a couple of weeks....."
It has 9038Pro. It has the slightest hint of "hump" but it is so reduced you wouldn't use it as an example of the 'problem' for sure.
Well, it is truly excellent. Okto DAC8 already got incredible IMD performance, and Matrix got it lower even further, by painstakingly experimenting and keep pushing the performance I'm sure. Very respectable engineering has been done here.Noted. I saw someone else mention this hint of ESS hump but amir only mentioned "Intermodulation distortion is likewise excellent"
Ak4499......i can't imagine what kind of beast would that be.Well, it is truly excellent. Okto DAC8 already got incredible IMD performance, and Matrix got it lower even further, by painstakingly experimenting and keep pushing the performance I'm sure. Very respectable engineering has been done here.
Of course, would be even better if ESS removes the symptom altogether. Then preferring AKM over ESS would be a moot point more than ever PS, you can edit your posts too btw.
That's great! Let's see the improvements!.I should be getting the first DAC with ESS hump fixed in a couple of weeks.....
Is that the Khadas TB with the balanced outputs also?I should be getting the first DAC with ESS hump fixed in a couple of weeks.....
