esp32 spdif input
netham45
I've made a decoder for receiving S/PDIF on an ESP32
How it works:
It uses RMT to capture raw pulse timings from a GPIO pin. It shoves these into a ringbuf that a processing thread pulls from.
The processing thread is ran on it's own core and converts from the RMT timings
The processing thread waits for a preamble it recognizes and decodes the SPDIF preample + PCM data from the input frame
It then waits until it has L,R samples then writes them to another ringbuf in sync to ensure channel sync
Usage:
Import spdif_in.h
Call spdif_receiver_init(<gpio pin>) to initialize the receiver, this will start receiving
Call spdif_receiver_read(buffer, size) to read data in from SPDIF
It runs the decoding thread on core 1 and is only just able to keep up on an esp32s3 set to 240MHz. I would recommend not running any other tasks on the same core and ensuring your CPU is set to full speed in idf.py menuconfig
With this I am able to decode and transmit spdif received from two different toslink devices (a TV, and a USB -> Toslink cable) just fine. I haven't tested on anything else.
I figured this might be a place where people would be interested in this.
Will give it a try!
Do you think it could be done so that it captures adat and/or 5.1?
Will give it a try!
You could for sure capture it for external processing but I'm not sure decoding those on esp32 is feasible
I don't capture all of the header info I believe is needed for that in this
Reactions: MCH
