ESI Juli@ XTe Sound Card
MRC01
Pacific Northwest
This was a popular card 10-15 years ago. I've had mine about that long. It's unique in that it has a daughter board that you can unplug & flip around to switch between single ended (RCA) & balanced (1/4" TRS) outputs and inputs. It uses the AK4358 for DA and AK5385A for AD. It supports PCM up to 24-bit 192 kHz, both input and output. For outputs, it also two digital: coax and toslink.
Summary: it was a great card for its time, still decent but nowhere near state of the art.
I tested it by playing REW frequency sweeps through a loopback connector. I'll show some unexpected results and ask questions.
Here's distortion & noise, SE, at 48 kHz, sweep at -0.5 dB digital:
Nothing special or surprising above.
Below is the same thing in balanced mode:
This is surprising: higher noise, about the same distortion. If you squint you can see the 2nd harmonic (light orange) is lower than SE, as expected with balanced.
Question 1: why is noise higher in balanced mode? Balanced should have lower noise!
Here's distortion in SE mode, with sweeps at 0, -1 and -3 dB.
Nothing surprising above. Distortion is slightly lower as you reduce the digital signal level below max.
Here's the same thing in balanced mode:
Well that is different: distortion is relatively constant at 0, -1 and -3 dB.
Question 2: why does distortion vs. level react differently in SE vs. balanced mode?
To help with this question, here are direct comparisons of distortion (not noise, couldn't get that to work in REW) between SE & balanced, at different signal levels. In each graph, SE is black and balanced is blue:
Sweep at 0 dB:
Balanced has slightly lower distortion up to about 1 kHz, above which it rises and SE is slightly lower.
Sweep at -1 dB:
Above we see the same pattern, though SE distortion dropped a bit while balanced remained the same.
Sweep at -3 dB:
Here, balanced has lost its advantage and SE has lower distortion across the board.
Sweep at -30 dB:
This is almost identical to the situation at -3 dB, but of course the levels are higher overall due to the lower level signal.
I used this card for years. First with analog outputs and then using coax and Toslink digital outputs. The driver software was more functional than that supplied with some other PCI sound cards.
I'm using it on a Linux (Ubuntu 18) machine. No driver or other software needed. Plug and play with the standard ALSA/Pulseaudio Linux sound system.
So does anyone know why balanced mode has slightly higher noise & distortion? That's the opposite of what I expected.
Has to be down to specific implementation details. I have a feeling that 0 dBFS levels in and out may be different for one, do they line up? Both are supposed to be +20 dBu (balanced) / +6 dBV (unbalanced) though, so not sure. I won't be too surprised if this modular concept (as genius a design it may be) is a bit prone to ground-related (and possibly contact) issues... I can't see it being particularly AES48 compliant either. There is no good reason for balanced showing much more in terms of power supply harmonics otherwise.
A bit of reverse-engineering might shed some light on the matter. Hmm, so just where did have have that old Juli@ floating around again...?
Yes, that noise looks like power supply harmonics. But... wouldn't power supply harmonics be equal on + and - (e.g. a ripple on the DC), so balanced mode differential signalling should cancel it?
That's what one would think. I suspect there is something fishy going on whenever you make a balanced loopback connection in particular. I would attempt to reverse-engineer the balanced receiver circuit, and if nothing obvious is found there, look at the grounding if possible. Since the circuit has both balanced and unbalanced inputs it is also possible that part of the signal path is actually unbalanced. I can't imagine that routing this analog board would have been much fun to begin with, there may well be some surprises lurking within.
Sweep at 0 dB:
Sweep at -1 dB:
Sweep at -3 dB:
Sweep at -30 dB:
You recently discovered this, or it has been like this since new? I wonder if it is caused by ageing or not.
The former. I've had the card for a long time, but never before compared SE vs. Balanced measurements.
Try this:
I had a problem that several USB 3 thumb drives were only able to run at USB 2 speed on my PC (both front panel on the case and sockets on the motherboard) after years of use. I was not sure if it is caused by the thumb drives themselves or the motherboard, or driver issues. At the end I figured out it was caused by invisible dust and dirt on the sockets. Applied contact cleaning fluid on either the socket or the plug, re-plug several times and problem solved LOL. Not that sensitive with USB 1 or 2 devices.
Can confirm. The front panel connector in my PC has rather loose-fitting contacts and the USB (2.0) is starting to act up again. I also revived a USB 3.0 thumb drive that would only work in 2.0 (and not at all in 3.0 ports) with contact cleaner once.
Still haven't come across the stupid card btw, I know it's around here somewhere and there aren't actually too many places it could be.
Perhaps you are right about the previous replies. The test on iXBT shows the exact issue, and yes, the PCIE version.
https://prosound.ixbt.com/hardsoft/esi/juli@xte/2444.shtml
https://prosound.ixbt.com/hardsoft/esi-julia-xte.shtml
My X-Fi PCIE card (of course, unbalanced) does not have these things show up.
https://www.audiosciencereview.com/...nts-of-evga-nu-audio-pc-card.9137/post-235666
Full RMAA report:
https://www.audiosciencereview.com/forum/index.php?attachments/x-fi-titanium-hd-zip.29512/
Back in the day, I knew this card was special because the pcb was white instead of green.
I am actually tempted to get their new Juli@ ex at 2026... somehow my PC geek have a place for internal sound card....
Juli@ is one of the few cards which report incoming SPDIF rate correctly and can handle subsequent rate switching of the software chain properly (at least using the linux driver, no idea about the windows one).
You mean this?
https://www.esi-audio.com/products/juliaex/
It looks just like my old one (form, function, breakout cable), but revised to use modern ESS DAC chips. At the price ($235) it looks like a good buy, not much more than the old ones go for used on eBay.
You mean this?
Yes, this one! just that with the lack of any review or measurement I am wondering if I should get this for my geekiness plus the $50 shipping to Asia from thomann, or just get the RME HDSPe AIO pro
Ended up I got a deal locally and bought a creative AE-X, to my surprise the RCA out is very clean, now my PC can have a good enough source dedicated to headphone gaming and no need to turn off the Genelec and the Equaliser APO for the main holospring dac for my hifi and movie consumption.
