ES9821 ADC – heavy odd-order distortion far from datasheet THD+N. What am I missing?
siarez
Hey, This is my first post. Looking forward to be part this community, and share more about my projects :)
I'm currently working on a current drive DSP+AMP combo. It is using a ESS ES9821 ADC and I’m seeing much worse distortion and noise than the datasheet suggests.
I’d really appreciate a sanity check from anyone who’s used this part (or similar ESS ADCs) before I write it off or redesign around something else.
1. What the datasheet claims vs what I see​
Datasheet headline (ES9821):
  • DNR ≈ 120 dB (A-weighted)
  • THD+N ≈ –112 dB (A-weighted, 1 kHz, −1 dBFS, 48 kHz, etc.)
What I’m actually measuring (directly from I²S):
  • Test tone: 1 kHz, ~−1 dBFS, 48 kHz sample rate
  • FFT of the raw I²S stream (24-bit in 32-bit slots) shows:
    • Fundamental at ~0 dBFS (within ~1 dB of target)
    • Noise floor around –115…–120 dBFS per bin
    • Dominant HD3 & HD5 around −70…−80 dBFS
    • HD2 & HD4 much lower (roughly –95 to –110 dBFS)
Using a least-squares sine fit in the time domain and treating the residual as noise+distortion, I get:
  • THD+N ≈ 58–60 dB at –1 dBFS
  • This matches very closely what I see from a QA403 audio analyzer on the analog outputs of the same system
So THD+N is ~50 dB worse than the datasheet, and the spectrum is clearly THD-dominated, not noise-dominated.
Below is the FFT of the decoded I2S signal at different input levels.
2. Hardware overview​
  • ADC: ESS ES9821 (two different chips, five indetical boards)
  • Sampling: 48 kHz, I²S, 32-bit word, 24-bit meaningful data
  • Clocking:
    • External 24.576 MHz MCLK
    • ES9821 running as I²S master for most tests (also tried slave)
    • No PLL in this mode (PLL disabled, direct MCLK)
  • Front-end:
    • THS4521 fully differential driver per channel
    • VOCM ≈ 1.65 V
    • ADC inputs are shorted differentially for noise tests (still biased at 1.65V)
    • For THD tests: ~1.78 Vrms differential at the ADC pins ≈ −1 dBFS (per ESS example conditions)
I’ve measured the front-end alone (at the ES9821 input pins) with a QA403: noise floor and very low THD, so the op-amp stage is not the limiting factor.
Supplies and VREF have also been checked on a scope and QA analyzer – no obvious HF junk or tones anywhere near big enough to explain what I’m seeing.
3. Measurement method (no DAC in loop)​
Early on I looked at the DAC output, but I’ve since taken the DAC completely out of the picture.
Current method:
  1. Capture ES9821’s I²S DOUT + LRCLK on a Rigol DHO804 scope.
  2. Decode the captures in Python:
    • Use LRCLK transitions to segment each 32-bit half-frame.
    • Sample DOUT at an empirically determined phase (~0.8 of the bit period) to stay away from edges.
    • Rebuild 32-bit words, then extract 24-bit samples (24-bit left-justified in 32-bit, arithmetic >> 8).
    • Convert to floating point in full-scale units (FS ≡ ±1.0 peak).
  3. Analysis:
    • Time-domain sine fit at f₀ (≈996 Hz) → signal RMS and residual RMS → THD+N.
    • FFT with Hann window and proper scaling → dBFS/dBV spectra.
    • Automatic extraction of harmonic bins (HD2…HD10) around n·f₀.
The I²S-derived THD+N numbers match the QA403 to within a few dB, so I’m confident the problem really is in the ADC output stream, not the measurement pipeline.
4. Register / mode configuration and experiments​
I started from ESS’s example register settings for 48 kHz and then tried a bunch of variations. Key points:
  • Clocking & system config (simplified):
    • 48 kHz, 24.576 MHz MCLK
    • 32-bit I²S
    • ES9821 as I²S master in one set of tests, as slave in another
    • No PLL engaged in this mode; direct MCLK
  • ESS-provided scripts:
    • Used their “SW_MCLK_MasterMode 24 MHz”–style scripts:
      • Enabling master mode
      • THD compensation (C2/C3 registers for both channels)
      • AUTO_FS_DETECT, 64× mode, etc.
    • Also tried their slave-mode config with PLL from BCLK in a separate experiment.
    • Result: only small changes (a few dB) in HF response / noise. THD and harmonic structure essentially unchanged.
  • ADC_CLK_DIV2 (Reg 0x02[7])
    • ADC_CLK_DIV2 = 1 improves noise by ~8 dB vs 0, but:
      • It somewhat improves harmonics,
      • THD is still dominated by HD3/HD5 around –70…–80 dBFS at –1 dBFS input.
      • ADC_CLK_DIV2 = 1 is out of spec according to the datasheet
  • FIR bypass
    • Bypassed FIR4x and FIR2x in the ADC path (ADC_BYPASS bits).
    • This shifts the noise floor and HF response by a few dB, but does not fix distortion/noise at audio frequencies (100 Hz–2 kHz).
  • THD compensation
    • Programmed THD-comp registers C2/C3 (Regs 55–62) with the values provided by ESS.
    • No measurable improvement in HD3/HD5 levels. I guess this is because those registers are not meant to fix this level of distortion.
  • I²S format & word length
    • Tried I²S vs left-justified, 16/24/32-bit word lengths.
    • No change in THD behaviour.
  • Master vs slave
    • Both ES9821-as-master and ES9821-as-slave to an external I²S master behave similarly in terms of THD/HD3/HD5/noise.
  • Chip sourcing
    • One batch assembled by JLCPCB (original suspect: “bad lot”).
    • One ES9821 sourced later from Mouser. Swapped onto a board.
    • Behaviour is essentially identical on both chips.
5. Distortion behaviour vs level and frequency​
Using a series of I²S captures and Python analysis:
5.1 1 kHz: Harmonics vs input level​
Input levels (approx, at ADC in): –1, –6, –12, –18, –24 dBFS.
Measured fundamentals and harmonics in dBFS:
  • Fundamental roughly follows input (linear within ~1 dB).
  • Example (1 kHz, ~–1 dBFS input):
    • Fund ≈ –1.7 dBFS
    • HD2 ≈ –106 dBFS (≈ –104 dBc)
    • HD3 ≈ –73 dBFS (≈ –71 dBc)
    • HD4 ≈ –94 dBFS
    • HD5 ≈ –74 dBFS (≈ –72 dBc)
As the input level is reduced from −1 → −18 dBFS:
  • HD3/HD5 in absolute dBFS change only a few dB.
  • In dBc, they actually get worse at lower levels (distortion floor is roughly fixed while the signal shrinks).
This is not what you’d expect from a simple small cubic term (which should scale 3× with level); instead it looks like a fixed nonlinearity floor in the ADC.
5.2 Harmonics vs frequency (100 Hz → 4 kHz)​
At a fixed level (around −1 to −6 dBFS), sweeping tone frequency from 100 Hz up to 4 kHz:
  • HD3/HD5 amplitudes in dBFS are essentially flat with frequency.
  • No strong trend of “distortion gets worse at higher f”.
6. Summary of where I am stuck​
  • Noise-only SNR (ignoring harmonics) is in the ballpark of 70–80 dB at –1 dBFS - not great!
  • But THD is dominated by HD3 and HD5 around –70…–80 dBFS, nearly level- and frequency-independent across the audio band.
  • THD+N ≈ 58–60 dB at –1 dBFS @ 1 kHz, confirmed both:
    • Digitally (from the I²S stream),
    • And analog-side via a QA403.
Given:
  • Two differently sourced ES9821 chips,
  • five boards,
  • Clean front-end,
  • And a lot of register/clocking experiments,
I’m struggling to reconcile this with the –112 dB THD+N claimed in the datasheet which I'm sure it's not a lie.
7. Other observations​
  • Poking, probing, and tapping the pins of the chip has no impact on noise and distortion level.
  • Sweeping the input bias voltage also did nothing to noise and distortion. (It only made it worse at extreme values)
  • All five prototype boards behave the same.
Finally​
Has anyone here:
  1. Run into a similar “odd-order floor” (HD3/HD5) that is:
    • ~–70…–80 dBc at –1 dBFS,
    • Fairly flat vs level and frequency,
    • With a high noise floor
  2. Is there any undocumented mode / calibration / clock tree combination / OSR setting that’s critical to achieving the published THD but not obvious from the datasheet?
  3. Any “gotchas” with:
    • SELECT_ADC_NUM, ADC_CLK_DIV2, FIR bypass settings,
    • or ESS’s THD compensation registers,
      that might silently drop the part into a lower-performance mode?
At this point I’m trying to decide whether:
  • I’m missing one crucial configuration/calibration step, or
  • I've made a grave mistake in my schematic/layout
Happy to share register dumps, small I²S captures, and the Python analysis scripts if that helps anyone reproduce or sanity-check the numbers.
Sorry for the long post. I did a lot of investigative work! And thanks in advance for any insights or “I’ve seen this before” stories.
Makes complete sense in hindsight. A clean, low-impedance VREF tends to be extremely important for high performance in both ADCs and DACs.
Yea, I do have a cap on VREF. I was missing the cap on VREF_BUFF. I assumed VREF_BUFF is just VREF that is buffered internally to serve as reference for external circuits. But when I probed it there is a 200mVrms noise on it, which tells me internal circuits are also drawing significant current from it.
