Definitely not an engineer or expert, but long time user, now mostly focused on HT. Couple of points.
95dB is not really that loud for peaks. Some peaks last longer than the others. If you listen at 85dB reference level HT material, your peaks could actually hit 105dB, especially if you run your speakers as large.
I have always wondered if the test signals actually capture the whole story, especially with any given speaker load at low frequency. If you have a 30hz peak (or even better more peaks below 100hz) that is 105dB, how would you fit that in the charts? If one had the REW compression charts for that signal from both amps perhaps that could shed some more light to what's happening?
