- Joined
- Jul 23, 2019
- Messages
- 572
- Likes
- 609
2dB is probably all it needs to bring it back to neutral and non-fatiguing on reasonable recordings.I honestly hope they don't bring the HF down more than 1 or 2 dB.
Adding some sort of "compensation" in the on-axis response for "narrowing dispersion" seems like a recipe for disaster. Creating a new problem, which this approach does, to ostensibly "fix" another problem, does not seem to be a viable long-term, recording-agnostic approach to take. It would be better to just have a flat on axis response and do the best possible with the rest.I think it would be a mistake to do more, because the slight rise in on-axis sound is compensating for the narrowing of the dispersion.
Can you elaborate some more on how the "error" fixed a "problem"?I have personally been in the position where a measurement error forced me to make a better design decision than I would have if the measurement had been accurate.
. A Mini is still a Mini, no amount of paint can hide that. You either like it, or not.
