highpurityusbcable
- Joined
- Jun 2, 2020
- Messages
- 196
- Likes
- 279
For quite some time I was under the impression that EqApo just doesn't work on my computer but it actually just doesn't work with WASAPI. After some searching I found a post where user explains that APO is using it's own sound processing which isn't affected by DirectSound. But after trying a new APO install I can only see Windows mixer samplerate on my D10s display. Usually I use "WASAPI event" mode in foobar2000 and "WASAPI exclusive" when I watch videos in mpv or mpc. In these cases samplerate is always showing correctly. I want to understand why do such big databases of presets for APO exist if it doesn't even support "bit-perfect" mode to bypass Windows mixer. Or maybe I am completely wrong and it actually does bypass it, just showing wrong numbers on display. Or maybe I was fooling myself for a long time, thinking that WASAPI is "cleaner" and DirectSound is the same? I can definitely live without a system wide equalizer, just using parametric eq in foobar2000 but it would also be convenient to maintain one preset for all cases.
Sorry if this post is a mess but if you've read it and have time to give an elaborate answer, please do.
