equalizer APO/peace not working
Gabrielzv1233
Hi, I recently just updated to Windows 10 Version 22H2 (OS Build 19045.4529), and the equalizer just stopped working, usually, it starts skipping when I update Windows, but I went and reran the configurator and restarted my device, no change, then I uninstalled the equalizer, restarted device and installed it again and restarted again, still no change. so I uninstalled my headset driver, restarted, uninstalled equalizer APO, restarted, installed, and restarted again, and somehow, it still doesn't work. one extra note is when I uninstalled the app I kept configs, no idea if that's a problem, it could be but I don't want to reconfigure my audio profiles (I have like 10 of them). and I haven't changed the default config at all so I assume it's not that.
Try doing a clean reinstall with Revo (with restart and registry cleaning).
I hope it helps. By the way welcome to ASR!
well i fixed it, but not how you would expect, i just kept rapidly switching between EQ profiles till it worked, and its working fine now.
It knows to get quirky from time to time, everything does even JRiver.
