I installed EQ APO and Peace, and I downloaded several equalization curves available online for my headphone model, but when I turn the EQ on and off, I don’t notice any difference. Am I doing something wrong in the EQ settings or somewhere else?
Run the configurator for EQAPO and make sure it's installed on the output device you are listening to. There should be a pretty noticeable difference with/ without EQ.I installed EQ APO and Peace, and I downloaded several equalization curves available online for my headphone model, but when I turn the EQ on and off, I don’t notice any difference. Am I doing something wrong in the EQ settings or somewhere else?
There is a separate utility / executable that comes with EQAPO called Configurator.exe and you need to run that before the EQ will actually do anything. It tells EQAPO which audio devices (i.e. DACs, soundcards, or other outputs) to run on. Before you do that step, it doesn't do anything whether you turn on the EQ or not.So, should I use only APO?
Is that correct?
So everything is configured correctly, but at the same volume, I don’t hear any difference between the equalized and non-equalized headphones.
Is this a problem of listening training, or of the type of music I’m using?
You can turn the EQ on and off quickly using the green/red button/switch highlighted previously in the thread.how can I compare the equalized headphones (with filters applied) to the same headphones without equalization?
I’m asking this to understand whether equalization has beneficial effects on the sound quality.
Can pink noise also be used to tell whether the headphones are properly equalized?You can turn the EQ on and off quickly using the green/red button/switch highlighted previously in the thread.
To make the effects of EQ more obvious:
The effects are most apparent when listening to harmonically dense, broad signals. To maximize that effect, If you listen to pink noise while switching the EQ on and off, it will be easiest to hear the difference.
Otherwise, listening to rock music with lots of distortion and loud drums will tend to carry the same characteristics and make it easier to hear the effects of EQ.
In terms of how you should listen for it - focus on one instrument or voice at a time, listen to the same section of music repeatedly, and turn the EQ on and off quickly.
If you are having trouble noticing the difference, the above should help it become apparent.
More generally, pay attention to: Are you hearing more details in the background of the recording? Do instruments sound more, or less balanced against each other? Do loud notes or tones "jump out" unpleasantly or jarringly, or do they still sit in the mix well? Does one instrument make another instrument hard to hear, or can you hear everything clearly at once?
Lastly, It's possible that your headphones are already pretty close to a given target and don't need much EQ to begin with. If the adjustments are only +/- 1 or 2dB, especially if the biggest adjustments are outside of the midrange between 100hz and 5Khz, the difference might be subtle and hard to catch while listening to music, especially Jazz or solo instrumentals.
If you can't hear it immediately with pink noise, though, I recommend you keep trying, as even slight EQ changes tend to be audible that way.
See here:how can I compare the equalized headphones (with filters applied) to the same headphones without equalization?
www.audiosciencereview.com
Yes, using a measurement jig.Can pink noise also be used to tell whether the headphones are properly equalized?
