EQ Software for Windows, Linux, macOS, iOS/iPadOS and Android.
Doodski
Doodski
_thelaughingman
@Doodski linking another new parametric EQ plugin thats available across Windows and Mac. Made by Eventide Audio that make many DAW plugins. Split EQ
hyperknot
@Doodski, can you add a not to ProQ 3, all Q values need to be multiplied by 1.41? Otherwise it is doing totally wrong calculations.
Doodski
Doodski
I'm not sure what you mean. Can you please elaborate a bit for me.
hyperknot
Pro Q3 uses a different system for the Q values, meaning that you cannot just use the Q values what you find here or on GitHub. You need to multiply each Q value by 1.41 (precisely sqrt(2)) to match the other EQs.
Here is the thread where I found this:
Doodski
Doodski
Alrighty. I added links to the description. I was running out of room for text on the one text line.:D
Acerun
San Francisco
USB Audio Player Pro is apparently not compatible with the Pixel 6. Is there a workaround or did I just lose this software?
somebodyelse
Acerun
San Francisco
807Recordings
Maybe a stupid question regarding IOS devices like ipad or iphone and Apple Music but many of these EQ's I have noticed never say they support Apple Music Streaming, and yet alone in lossless. Is this correct?
lofiguy
I don't understand why Audiohijack [sic; it's actually Audio Hijack] is described as "not bit perfect"? All equalizers are by definition not bit perfect ...
Also, all hosting software that works for routing on the Mac is not bit perfect, AFAIK. Or rather, it's not up to them. The source app will have its own volume control and it's up to that app to have unity gain setting or not. Almost all do not, apparently.
There's a second thing going on with sample rate. Audio Hijack does not follow the source's sample rate if it changes. If that's what the "not bit perfect" is about then that should be annotated. But anyway it's listed as an equalizer -- which is just one of its functions. Which is really executed by a built-in AU plugin for that function. Anyway I refer back to my original point that equalizers are not bit perfect by definition.
