EQ Software for Windows, Linux, macOS, iOS/iPadOS and Android.
Does anyone know if there is a keyboard shortcut to bring up MathAudio Room EQ interface on the screen in Foobar2000 instead of having to go into Preferences/DSP Manager first?
I was able to create a Foobar2000 keyboard shortcut to bring up the DSP Manager, but not able to have it open up MathAudio Room EQ in one go.
File/Preferences/Keyboard Shortcuts/Assigned shortcuts panel/Add new and define your own shortcut. Select View/DSP/DSP #1 config as the action if MathAudio Room EQ is your first DSP effect on the list. You can also save your complete DSP chain preset and assign it to some shortcut to apply it directly in one go.
What about the one everyone uses. VLC?
File/Preferences/Keyboard Shortcuts/Assigned shortcuts panel/Add new and define your own shortcut. Select View/DSP/DSP #1 config as the action if MathAudio Room EQ is your first DSP effect on the list. .
How do I do that? Right now MathAudio Room EQ does not show up under View/DSP. The only thing that's there is Equalizer which is the Foobar2000 built-in EQ.
Sorry, realized right now you have to install foo_dsp_effect VST 2.4 adapter plugin for this option(s) to appear. DSP #1 config is the first active DSP from your DSP Manager list, DSP #2 config is the second active DSP from the list and so on...
Sorry, realized right now you have to install foo_dsp_effect plugin for this option(s) to appear. DSP #1 config is the first active DSP from your DSP Manager list, DSP #2 config is the second active DSP from the list and so on...
Installed foo_dsp_effect plugin and saved a DSP chain preset under "DSP Manager". Still not seeing what you are seeing. Under "View" it just shows the standard DSP effects that are part of the foo_dsp_effect plugin.
Now, I am seeing the DSP presets under "Playback/DSP Settings", but creating keyboard shortcuts to these doesn't actually do anything. The shortcut saves, but pressing those assigned shortcut keys doesn't bring up anything.
Huh, weird, seems it is not a part of this plugin then :oops:. I scratch my head where those options come from. Uninstalled this plugin now and still have these options. What version of f2k do you have installed? I have the latest 1.6.2.
Finally figured out, it is a part of the VST 2.4 adapter plugin (v0.9.0.3) :).
Yup, just figured it out, too. Got it all working now - even ability to switch between several different MathAudio Room EQ presets just by using keyboard shortcuts - that's what the Playback-->DSP Settings stuff is for - when you press those keyboard shortcuts nothing pops up on the screen, but it does switch to that respective EQ preset. Awesome! Thank you.
OKidoki. I got the, "Pulseaudio Parametric Equalizer is a python GUI to insert a 3 band PEQ w/ high/low shelves into the pulseaudio audio server."
The crossover software I never added because this is a EQ thread.
After suggestions from some peeps about adding crossover software it might be good to create a thread for crossover software. :D
Thanks muchO. :D
I'll suggest another software for those who are more hands on, MathWorks has an Audio Toolbox that can produce or host audio plugins. So you can deploy your own VST, AU or standalone plugins directly from MATLAB code. There are also tunable filters, etc., so often there is little code to write to get going, but it's definitely for those who want/can develop their own thing.
Any suggestions are welcome. Post suggestions here. I will gather the details and add them. Thanks. :D This will be organized as results come in.
Windows:
Equalizer APO is a parametric / graphic equalizer for Windows.
PC Equalizer is a Graphical User Interface for "Equalizer APO" which is a parametric / graphic equalizer.
Peace equalizer is a Windows PC interface for Equalizer APO.
REW is free room acoustics analysis software for measuring and analysing room and loudspeaker responses.
foobar2000 is an advanced freeware audio player with EQ.
VLC is a free and open source cross-platform multimedia player w/10 band EQ.
MathAudio add-ons Room EQ VST, VST3, AU and Foobar2000 component.
Roon manages the music from all your digital sources: TIDAL, Qobuz, NAS, hard drives, iTunes, live radio and includes a parametric EQ.
Neutron Music Player audiophile-grade platform-independent 32/64-bit audio engine, parametric EQ.
CamillaDSP supported platforms: Linux, macOS, Windows.
Boom 3D Desktop 31-band equalizer, 3D surround.
Realtek HD 10 band EQ for Realtek audio chipset.
FxSound Enhancer uses EQ presets.
Sonarworks Reference 4 calibrates your studio monitors and headphones.
Waves EQ plug-ins
Equalify Pro a 3rd party desktop plug in specifically for Spotify.
ToneBoosters Equalizer 4 all-purpose dyamic equalizer with AI assist functionality.
Toneboosters TB Equalizer v3
Toneboosters Morphit hundreds of headphone profiles
Sonic Studio 3 for ASUS motherboards.
JRiver comprehensive and seamless software available for managing and playing your media.
Voicemeeter Banana virtual mixer with EQ and audio routing capabilities, integration with VST host software.
FabFilter Pro Q 3 up to 24 EQ bands.
EKIO is a comprehensive loudspeaker management application. It lets you customize the sound of your loudspeaker system.
ARC System 3 - Acoustic Correction System 2 types to choose from.
oratory1990 is headphone specific equalization.
AutoEq uses EQ profiles to be used with EQ software.
CanOpener Studio EQ with Crossfeed plugin.
Boom3D and Boom2 10-band & 31-Band Advanced Equalizers.
HQPlayer PEQ, a convolver with impulse response files, cross-feed and multi-channel support/mixing/routing.
Linux:
PulseEffects signal processing tools including parametric equalizer.
Camillagui runs in the browser and handles the actual interface.
dsp is an audio processing program with an interactive mode.
Daphile is an audiophile class music server & player OS – targeted to dedicated headless PC.
moOde audio player parametric and graphic Equalizers music playback for the wonderful Raspberry Pi family of single board computers.
Voicemeeter audio mixer application w/ virtual audio device used as virtual I/O to mix/manage any source from/to any audio devices or applications.
DSP for Volumio (previously Brutefir3)
BruteFIR - the convolution engine used by daphile, Volumio's DSP plugin, an LMS plugin and probably others, also manually configurable in a custom alsa config, JACK etc. You can also use it to make crossovers.
BrutefirDRC - the LMS plugin that uses BruteFIR running on the server, configurable per endpoint. Archimago has a howto.
Jconvolver - formerly Zita-convolver, the convolution engine used in PulseEffects, which can also be used with JACK.
Alsaequal - an equalizer you can add to the alsa config. Basic usage is a fixed band graphic equalizer, but it can be used to give a control interface to any other LADSPA plugin via the usual alsa mixer interface. The normal alsa config for ladspa plugins only allows fixed configurations, although for something like an active crossover that's probably an advantage.
foobar2000 is an advanced freeware audio player with EQ runs under wine.
Plus there's a whole host of LADSPA plugins you can use via JACK, alsaequal, or with a fixed configuration in the alsa config file. A good example is the PE32LR parametric equalizer from the Linux Studio Plugins Project which provides the parametric equalizer for PulseEffects.
MacOS: (System wide parametric EQ solutions on OSX typically rely on separate plugin hosting software and the actual plugin which does the actual equalization.)
Audio plugin hosts include:
MenuBus has a free version but is no longer actively developed.
SoundSource is in active development but not free.
Hosting AU with BlackHole or Soundflower can be used as a system wide AU plugin host.
EQ plugins include:
Voxengo PrimeEQ is a parametric EQ plugin but is not free.
Fabfilter Pro Q3 is another parametric EQ plugin, more expensive than Voxengo but might be easier to install and use.
LAConvolver plugin is a free convolver EQ which works with impulse response WAV files.
EQE is a system wide parametric equalizer on iOS but requires jailbreaking.
Universal Audio Equalizer for Mac OS X
eqMac 10 band EQ.
Audirvana can do bit-perfect and exclusive access but can't do system level hosting.
Audiohijack can host system level DSP, including those EQs. The only downside is that isn't "bit-perfect."
Toneboosters Morphit hundreds of headphone profiles.
AU Lab the download link is at the bottom of the page.
iOS/iPadOS:
SoundID by Sonarworks, uses Reference 4 profiles.
Neutron Music Player an advanced music player with audiophile-grade platform-independent 32/64-bit audio.
Android:
Wavelet is headphone specific equalization.
USB Audio Player PRO has Toneboosters Morphit plugin which has parametric equalizer.
Music Equalizer EQ 10 band equalizer.
Viper4Android a system-wide convolution based equalizer.
JamesDSP 10 Band Hybrid Equalizer.
Sonarworks True-Fi 287 supported headphone models and counting.
Equalizer FX. Pro 5 band EQ with effects.
Neutralizer
Dolby Atmos
Poweramp Equalizer based on Poweramp player.
I just wanted to say thanks for doing this! Much appreciated!
