EQ Software for Windows, Linux, macOS, iOS/iPadOS and Android.
Hello guys,
Is there any software Windows so as to use EQ while streaming Qobuz, Tidal enabling bit-perfect option?
I see Roon but is much expensive for everyday use.
Is there any free or budget friendly solution.
Thanks
Hello guys,
Thanks
If you use EQ you cannot have bit perfect output, unless I am misunderstanding what you are asking.
Two asks :
Are there any EQ plugins(e.g VST, VST3, AU) , that correspond to one of the supported EQ devices on AutoEQ.app?
And are there any EQ plugins, that correspond to the correction EQ settings generated by Sguig.link?
The reason I ask is, not all parametric EQ's are identical. Typically they vary in how they achieve the Q (bandwidth) of each band. Therefore assuming that one can plug in values form AutoEQ.app, or squig.link, into any parametric EQ, is just that, an assumption, which could lead to disappointing/incorrect results.
Most correction EQ apps, seem to be able to generate the settings for Equaliser APO, which can then be used to implement EQ, in the Windows audio chain, outside of any app.
I recall being advised on an online forum, that the Melda Productions, free parametric EQ is compatible with Equaliser APO, but I can't be too sure. My challenge when using Melda Productions free parametric EQ, was, it had only 6 (maybe only 4) bands, so when REW(Room Equalisation Wizard) generated any more than 6 bands, it was impossible to implement these in Melda Productions free EQ., which is why I have raised the two questions above.
In theory YES, this is correct. Any processing in the chain, breaks the bit perfection of the audio stream. Modifying it in some way.
But it could be argued that in today's world, where it has become possible and the norm, to process the audio, using digital EQ, digital crossfeed, gain changes or stereo balance changes all achieved digitally, as examples. One may relax the definition of bit perfection, to apply to, an audio stream that does NOT change bits, in any arbitrary manner, except when explicitly instructed to do so, by the end user, via apps which have access to the audio stream., i.e excluding any deliberate manipulation of the audio, from the objective of bit perfection, as this was an intended alteration, of the signal.
It's very likely, there will be some kind of bit manipulation somewhere along the audio path.
Sorry but as I know Roon and Audirvana can integrate with streaming services such as Qobux/Tidal with bit-perfect exact track bitrate and not Windows resample and at the same time using EQ for our headphones applied. Is it right? If yes that is that I am searching for.
As APO/Peace can EQ but when run bit-perfect with Qobuz/Tidal EQ is deactivated.
I see no reason to pursue bit perfect playback, you'll never hear any sort of up/down sampling that may be used. Just there to make people feel better about their playback being more "pure".
I can not tell my self an audiophile as I use my HD600 and a dongle dac to enjoy my music and I am till now almost happy with that. But I can feel not say but feel different the music when choose bit-perfect on/off. I feel the music fuller and somehow cleaner, but maybe is my idea as I can not prove it at all.
Also with bit-perfect Windows as I think do not messed up with the bitrate of resampling and I can use the better bitrate that Qobuz/Tidal provide, instead of whatever bitrate Windows device passes on
Very much this.
While I agree with you pretty much on everything you say, I think it's risky to change the terms we use to indicate stuff. It's been hard enough to settle down on the current ones, after all... :)
That's a too simple statement.
For whatever software that's handling the extraction of the digital stream off the source, I do want to know that it is not altering that stream in any way.
I don't want my media player to be messing about with things, at least in ways I don't ask for.
I prefer to know what's coming off my files or CD hasn't been altered until I make a decision to do so.
Just placebo and bias.
I think what varies is the gain/Q interaction. I get crazy with the internal EQ of my older Motu interface which has 4 types of EQ with varying "gain/Q" and none seams to ever match what other software uses.
Can you turn off oversampling in your DAC? Do you?
That's not the point, we're not talking about re/over sampleing in the DAC.
What my DAC gets should be unaltered.
If you have a crappy DAC that's messing up the SQ, get rid of it.
I don't want my disc ripping software to alter the data stream, I want a bit-perfect copy.
I don't want the media player doing EQ, level, balance, or any other changes before the DAC.
Bit-perfect implies no EQ afaik..
However, ignoring that, here is one recent approach to applying EQ to those services (from our own ASR DSP expert - MitchCo).
HLHost is $20. There may be other capable SW stacks, too, but I am primarily familiar with the HLH method.
Apply EQ to Qobuz or Tidal
HTH
The question was regarding maintenance of 'bit-perfect' in the playback chain and the DAC is certainly in the playback chain.
Nobody said anything about bit-perfect copies being made from CD, I doubt if anyone on here would argue that AccurateRip is not a good thing.
Why would you not want the capability to apply EQ, level and balance changes in the digital domain?
That's the best way of course, but not locked into the stored ripped files or media player software.
Of course you can, but it's an as-backward place to do it.
Before the DAC is the place folks talk about being sure the file is bit-perfect to the original source.
While I understand, completely, not wanting to modify the source material, I don't see why it should be a problem applying equalization in the media player software.
No problem if it only serves one full system.
A real hassle if you swap to speakers in other rooms, headphones, etc.
