The comment likely refers to EQ Mac, a system-wide equalizer application: https://eqmac.app/Which equalizer on Mac are you talking about?
And above all, before buying the RME which interface / DAC did you use?
I used Eq Mac, and IFI Zen One Signature, but I also try Eq Mack ones with my RME to hear the difference, and it was obvious, with RME EQ the sound was clearer with a darker background.Which equalizer on Mac are you talking about?
It is very unlikely that you hear a difference between digital equalizers. To get a valid test you should do an ABX test with the same identical settings for both the parametric equalizers, especially as regards the Q Factor and type of filter (that may not be so simple to know).I used Eq Mac, and IFI Zen One Signature, but I also try Eq Mack ones with my RME to hear the difference, and it was obvious, with RME EQ the sound was clearer with a darker background.
It's not very clear how it works...cavern is pretty damn awesome.
Experience incredible flexibility with Cavern, the powerful audio processor that enables object-based sound on systems where it was previously unimaginable. Cavern is the first ever PC audio processor that supports Dolby Digital Plus Atmos, and has the tools to convert your content to any channel layout in a channel-based format.
Get ready to be blown away by the incredible audio quality achieved with quickeq Cavern's lightning-fast automatic calibrator that outperforms even actual cinema processors with ease. Don't settle for mediocre sound quality. Upgrade to Cavern and discover the full hidden potential of your audio setup!
Cavern
Free room correction suite and Dolby Atmos decoder for PC. Improve the sound quality of your home theater and enhance your listening experience.cavern.sbence.hu
For windows.
Thank you. I added this to the list near the top under Peace EQ.cavern is pretty damn awesome.
Cavern
For windows.
I sifted through all the plug-ins of which there are many and did not find a EQ or PEQ listed. Can you point me in that direction?Sparta collection is more awesome. But It's not intended to be used by normal people who have a life and shit.
"SPARTA is a collection of flexible VST/LV2 audio plug-ins for spatial audio production, reproduction and visualisation, developed primarily by members of the Acoustics Lab at Aalto University, Finland.
The SPARTA installer also includes the COMPASS suite, the HO-DirAC suite, CroPaC Binaural Decoder, and the HO-SIRR room impulse response renderer. These plug-ins employ parametric processing and are signal-dependent. They aim to go beyond conventional linear Ambisonics algorithms, used by the baseline SPARTA plug-ins, by extracting meaningful parameters over time and subsequently employing them to map the input to the output in an adaptive and informed manner."
Spatial Audio Real-Time Applications
A collection of open-source VST, VST3, AU, LV2 and AAX audio plug-ins for the production and playback of spatial sound scenesleomccormack.github.io
For cross-platform, perhaps Neutron MP.Hi guys,
Please let me know your recommendations for both IOS and Android.
+1Are there any equalizers for Windows that can be used without installation? I use Equalizer APO for my personal pc, but on my work laptop I cannot install anything like that. Just need it to work for Spotify (Spotify's equalizer is ass).
Has there been any updates regarding VSTs equivalent to EqualizerAPO?
I know this question has been asked a few times across a few forums, but I have yet to find any actual answers.
I started routing my audio through Ableton instead of EqualizerAPO for lower latency and more control but gave up AutoEQ as a result. I know I can use VSTs like Boogex to import an IR, but that doesn't cover EQs from other people who cannot provide an IR.
From my knowledge, which isn't a lot, there is no way for me to import these EQ files from squig.link autoEQ into any of these parametric EQs. I could technically do them manually, except for the fact some of these EQs go over 8 bands, frequencies, filters? I don't know what they are called.Ableton has a parametric EQ.
I was a bit unfamiliar with the term filters and pass bands but it becomes more familiar with use. The mental somersaults are present but not out of reach for most people. I have used the mic method, the moving mic method and the old school pink noise method and I always revert back to tuning by ear. So there's always that.From my knowledge, which isn't a lot, there is no way for me to import these EQ files from squig.link autoEQ into any of these parametric EQs. I could technically do them manually, except for the fact some of these EQs go over 8 bands, frequencies, filters? I don't know what they are called.
