- Joined
- Mar 29, 2021
- Messages
- 2,392
- Likes
- 4,115
Both Rock Pi S and Orange Pi Zero have OTG on the power supply port. That is the the source end. Standard USB A is the DAC end.Cool idea. A potential miniDSP clone for less than $50?
I admit I'm unclear on the audio input/outputs? I see one USB on the O-Pi Zero?
More than its cost, I think the coolest thing about it is the fact that its an open source and open ended solution. You can add Spotify Connect, AirPlay, DLNA, UPnP or even Roon Bridge I believe so it is also a streamer if you like, i.e. miniDSP + Wim Pro. You can integrate Harmony Hub into it and control it from voice asistant as well if you like, so you can shout "Alexa, set the speakers to to movie"to boost mids to hear conversations better. Whatever you can develop yourself, whatever you can find on Git and whatever you can imagine is the limit. I am loving it.
