EQ Software for Windows, Linux, macOS, iOS/iPadOS and Android.
I’m getting music from two sources:
1 - Amazon Music HD
2 - WMP for ripped CDs on my NAS
On my pretty standard Dell Windows Laptop, through Equaliser APO USB into external DAC.
Any pitfalls I need to know about? Any reason this won’t be passing the digital bits unadulterated?
Software EQ, by its essential nature, adulterates the digital bits.
Ah - that would depend on the exact definition of adulterates! Neither of my headphones are made worse/corrupted/"rendered poorer in quality" by the application of a spot of EQ. The fidelity of the original signal is compromised but only in an attempt to counteract what the headphones are doing to the signal. I think it's doing the opposite of adulteration!
Before we go off on a tangent (and thanks for the input) back to my original question, please.
Will Windows be doing anything nasty in-between the original file/stream, and the DAC?
Cheers.
Cheers.
When using a player capable of ASIO/WASAPI you get bit perfect transmission without any interaction of windows.
Cheers.
Well, strictly speaking if you're not talking about applying EQ then it is you who are going off on a tangent, given the subject of this thread... :)
Firstly, I am using it for EQ.
Secondly, I wasn't pedantically screaming ‘off topic’, I was just trying to bring discussion back to my question.
I use a miniDSP as my PC soundcard, it has 10 x PEQ w/ import from REW.
4 profiles: 3 for different HPs and 1 w/ PEQ + xover + delay for amp + sub. I can get wide staging with the centre spot right bang in the middle of my 49" ultrawide w/ the speakers at different distances. You could theoretically have profiles for 8 x HPs as each profile is for 4 outputs.
I've tried a couple of SW APOs (Boom3D wasn't bad), much prefer the on device, always on, easier... as Win SW is never 100% system wide.
Hi there, anyone know of an equalizer app that would work with a music streaming service on ipad? Im trying to figure out if there is something that could used for any of the streaming services.
Thank you.
@Doodski Can we please add Waves Q10 plugin as a PEQ solution for MAC OS please. I am currently using it and it is fantastic.
This is Q10 with Sennheiser HD560s EQ.
Anyone else having trouble getting EQ APO/Peace working after the latest W10 update? Even a re-install didn't help.
I see the loudness bars moving with the music but switching on/off the EQ does nothing.
I tried to apply a pre-gain of -7db which should be an obvious difference in loudness, just to make sure... Nothing.
Me.
