EQ plug-in for JRiver w/Windows 10
bt3
Recommendations for plug-in equalizer for JRiver (old version 21)? A good free one better on my budget. I'd like to start trying to apply and save the EQ profile Amir applied to Bose QC35II headphones. Another member posted EQ settings that would apply Amir's settings also:
Preamp -2.5dB
32 -0.4
64 -0.2
125 -0.2
250 -0.2
500 -0.3
1000 -0.3
2000 -0.4
4000 +2.6
8000 -1.3
16000 -0.3
I cannot apply these settings on my JRiver 21 Graphic EQ or Parametric EQ.
I have better headphones just for music listening that I'd like to apply/save some EQ profiles on as well.
Thank you.
Patrick1958
Belgium
Preamp -2.5dB
32 -0.4
64 -0.2
125 -0.2
250 -0.2
500 -0.3
1000 -0.3
2000 -0.4
4000 +2.6
8000 -1.3
16000 -0.3
Thank you.
Yes you can.
apply a Q 1.41 on above settings in the JRiver PEQ and should be fine.
daftcombo
I have JRiver 24 and the PEQ is working fine.
Otherwise download Rephase, create an impulsion based on those settings and convolve it in JRiver.
