- Joined
- Jun 10, 2018
- Messages
- 6,222
- Likes
- 9,343
The above REW screenshots are of my LS50's crossed over to a single sub at 80-ish hz. The first is 1/6th octave smoothing which is how most of these graphs are presented. Next is psycho acoustic smoothing which is supposed to be what we hear. Finally is variable smoothing which is what the author of REW recommends we use.
The house curve is another variable. This is the one @mitchco described elsewhere, +2 db @ 20 hz, -8 db @ 20 khz. Use your imagination for B&K, Dirac or whatever. I can't tell you what's best, but if it doesn't slope down in the highs it will sound bright. The LS50's are 30 degrees off axis, by the way.
If I lower the target level from 91.5 to 91 REW reports no filters are needed for a 2 db target from 20 to 250 hz. That's three more variables, target level, target tolerance, and EQ range. Also hidden are individual maximum boost (8 db) and overall maximum boost (2 db).
There's a lot going on. Many say don't EQ beyond Schroder, which is about 200 hz in typical homes. Higher in a Japanese rabbit hutch and lower in McMansions. I have seen comments by @Floyd Toole that you can go as high as 400 or even 500.
The smoothing makes a gigantic difference in the number of filters generated. Anywhere from none to 12 when all other things are equal. I can tell you what I can hear. Reducing the bump at 68 hz reduces subjective quantity bass, but not the quality. Taking out 2db of the sag at 160 hz changes the timber of Leonard Cohen's voice to one which sounds more natural to me, especially on his later recordings. Attempting to take out the twin peaks on either side of 550 hz gives me the impression of increased harshness, the opposite of what I predicted.
As noted above the author of REW says use variable smoothing for EQ. Others around here say don't go any smoother than 1/12th. In one pro audio forum I found comments like, "don't knock yourself out, use psy or 1/6th.
Nobody here can really tell anyone else exactly which filters to use in their system. The best anyone can do is provide a systematic method. That's because the right answer involves personal taste and individual quirks.
Anyone here want to talk about EQ?
