EQ apps for Android
For now you can make EQ profiles for wavelet from scratch, squig.link style websites, including crinacle's, can export directly to wavelet format. Not as great as having PEQ in the app but still manageable to do entirely on your phone.
This is what I do, it's flexible and works for all apps I use on Android. Highly recommended.
I really want to make additional changes to peq over the autoeq profile. Not just the bass boost. It would be nice to have additional functionality
Mega Switcher can do that, but it's Windows-only. :p
Does it have Android 9 or newer? Because that's a requirement. If that's not it then your best luck would probably be the Wavelet Github repo issues ie asking the developer.
It is not. He can sideload any app and Wavelet will in most cases work to the default Android audio chain with legacy mode enabled (including BT). It won't work with apps that use their own costume USB audio driver's. For full future set from which some are quite useful not to say essential you have to pay. On Xiaomi it's advisable to disable all MUI additional audio processing.
Is there a good video player with built in peq for Android?
You can make Wavelet output over almost anything (in legacy mode including to BT). It's not PEQ but many point GEK (similar to tap convoler) and you can mod it by hand (easy to understand txt header) or bake half costume or to other headphones (error) response with Auto-EQ next to included default template ones. It's for headaphones/earphones only.
If you don't mind mindless add's from time to time try Mi video player for support for most HDR videos (including Dolby Vision and AV1 both requiring adequate hardware to work). If you do and don't need those VLC will do the job just fine.
