I'm working on my house curve using REW. I'm using the MMM technique at my listen place. I want to EQ only for this spot.
First which smoothing is best for HF eq : 1/3, 1/6, 1/12?
Second with REW's auto target caculator I have a 1,5db difference between speaker L and R (44,1db And 45,6 db) (speakers are at the same distance) Should I use 44,1db, (the lowest) target for both speaker? Intuitively I would say yes.
Third the speakers crossovers are 600hz (miniDSP), I plan to EQ between 20 and 300hz. Auto HF eq using REW is mostly from 2000 to 20khz. What about 300 to 1000hz? REW suggest one or two EQ correction in this region, mostly lowering peaks (Q >4). Should I leave it untouched or trust REW's recommendation? I tested with EQ in this region and it sound good and got consistent measurements too.
I'll be able to post mdat later.
