Logan Nolag
- Joined
- Sep 7, 2020
- Messages
- 65
- Likes
- 28
So I just picked up an RME 802 FS AE and I’ve been experimenting with its built in Room EQ feature. After several hours of testing in REW this is my best result. I have a 2.2 system with symmetrically placed subs just to the left and right of the main speakers.
The purple trace is with no eq just a high/low pass at 80hz. The blue trace is the fully EQed result.
My biggest issue is right around 80hz. I was able to get my left speaker and left sub to integrate pretty well but my right speaker seems to produce a massive null around 80-90 hz all on its own even without subs.
The massive peak right next to the 80hz null is also coming from my right speaker. When I combine the left and right subs together with the right speaker it results in that double null on either side of 80hz.
I tried literally every combination of polarity and phase in my svs subs. I took measurements from 0-180 degrees phase in 10 degree steps with polarity set to both positive and negative and then set the subs to the result that integrated best but no matter the phase or polarity I couldn’t completely eliminate the null and this was the best I could do.
I was able to eliminate the null and peak in the right speaker by running no crossovers on the subs or speakers at all but it would come back after applying eq.
