I hope Topping is not offended by this modification
I am very satisfied with the very good sound and finishes of this DAC and its quality / price ratio, that's why I bought it. Good finishes and internal machining. I liked seeing the solid aluminum keypad and the front glass and not plastic protector.
But one of the details that I did not like, are the handling of the menus and especially the volume, through the keyboard.
It is not important, when I also have the headphone amplifier at hand, but it has served me more than anything else as entertainment and approach, because it needs improvement to be really practical. The size, the finish, and specially in the number of beats per turn, which do not seem enough to me.
At the moment, I have not wanted to make changes to the electronics or mechanics of the equipment. It is mounted with remains of CD players, etc. Maybe I will take it apart, maybe I will improve it.
The operation is very simple. On the DAC, each of the buttons on the front, up and down, ground a contact.
I have used a ribbon cable for connections which could have been smaller, only three wires are needed and black in color.
The central strap, of a limit switch, serves as a spring to center the button so that it does not make continuous contact, and the lateral contacts have internal springs to cushion excess travel.
The gear itself selects the repetitive contact according to the direction of rotation. The more teeth, the more contacts one way or the other.
Perhaps I will modify it with a gear with internal teeth to increase the speed of the contacts. The rest is done by the routes and distances to avoid excessive rebounds.
A greeting. I hope it will at least entertain you for a while
Good machining
Only three threads are necessary, if I make another version I will change it for one with fewer threads or I will use fine thread to wind transformers so that it goes more unnoticed. Although not seen from the front
Good machining
