A thread on which to share my plentiful electronic and electromechanical OSHA violations shenanigans. Engage safety squints.
I have recently been working on quite an elaborate video for the YouTube channel (which will hopefully be complete in a few days) and some of the shots required motion control, for which I hastily cobbled together a rig.
Several steppers and controllers very hastily thrown together but the result was pixel-perfect repeatable motion for the multi-pass shots which required it. No gearing for the steppers but the microstepping in conjunction with loading were sufficiently smooth. For the programming, I took the brute force route rather than attempting to make use of an existing motion control library. The code will probably end up on Github soon.
I am now down to the final few shots but as usual, unexpected complications have arisen. The AVR chosen for the demonstration doesn't seem to be producing any audio via the newly installed post-DSP SPDIF output.
BCK is there, MCK is 24MHz (512*fS), LRCK is fS(48KHz) and the SPDIF output scopes as expected when muted but there is no actual audio. First course of action will be to replace the RCA connector, just in case it happens to be defective.
There is also the possibility that my XDA-1 isn't happy with the WM8804's transformer isolated output, so I will also be trying a TTL output via TOSLINK in the event that the connector isn't the culprit.
More at 11.
More at 11.
