Endgame passive bookshelf shootout: KEF Reference 1 Meta vs. Ascilab S6B
interesting. I am currently debating between a 6.1.4 all KEF system with the Reference 1 as mains or replacing them with the S6B and getting F6Bs for surrounds. Only problem is AsciLab currently doesn’t offer dedicated height speakers.
The F6Bs is designed to allow installation of a VESA 100 bracket on the rear, enabling it to be mounted on the ceiling or wall, and making it suitable for use as a height speaker.
That’s really good to know thank you. Do the grills for the C6B also fit on the S6B? Would be nice to have the black driver covered in front of my white wall to make them less distracting.
If not are grills in general rather not viable to make for the purify drivers because of the purify surround and high Xmax?
I appreciate any reply
The S6B is an all Purifi design, I am pretty sure the C6B’s grills will not fit on the Purifi drivers because of their crenelated surrounds.
Thank you. Yes AsciLab confirmed that. Looks like the Burchardt grills are an option.
The C6B grille is different in size from the S6B and A6B grilles.
The A6B has a dedicated grille, while the S6B only has a grille for the front 6.5-inch unit. This grille is the same as the A6B grille.
I considered the Genelecs too and would be fine with the active nature given Genelecs reliability, but the look of it somehow bugs me too much.
Neumann then.
KH150
Frequency_response
Zz1hZjAxNGQ1NGRjMjAxMWYwODZlZjdlYzU3ZTZkYjAwMw==
Looks
Zz04NjE5MDNkOGU3YWExMWYwOGNiZDJhMzQxNzliYzkxZA==
cheers
Ästhetically I definetely prefer the KEF‘s. I agree you can’t really go wrong with either.
I am maybe a bit conservative, but I just don’t like the active concept for expensive speakers I intend to keep for life.
I have compared the Reference 1 and R3 in two different rooms. expecting not much of a difference and was suprised that I liked the reference 1 way more.
Thanks for finding that!
You mean the R3 meta or the Reference 3 meta
Can't go wrong with either. But I personally would go with the KEF due to the lower distortion level. Also, while I like big soundstage, I'm ok with a narrower soundstage in trade for a better phantom center imaging. I believe the reference is matched to .5dB to the factory reference, if I am not mistaken.
KEF is point source due to the concentric drivers, but the Ascilab essentially achieved point source based on their amazing design.
Ascilab get dig a little bit deeper, but I'm willing to sacrifice a bit of bass for a lower distortion profile.
Hello everyone,
which one, is in your opinion, the overall better speaker and why? Which one would you pick?
KEF Reference 1 Meta: ported 3 way design (coaxial plus woofer)
dimensions: 44x20x42cm
Ascilab S6B: 2 way using purify woofer and tweeter plus passive radiators
dimensions: 40x22x30cm
---->Reference 1 is quite a bit larger
I could not find any compression data for the S6B.
Unfortunately there is currently no option to demo the S6B in europe. I heard the reference 1 multiple times and it sounded great to me.
Since i intend to keep these for life (fingers crossed) and will probably move a lot in the future i make the decision quite independent of the room. I value engeenering and performance even beyond audible benefits.
Money is not a concern, i just want the best passive bookshelf i can find. if you can think of any better passive bookshelfs let me know.
I am curious about your input.
thanks in advance for taking your time to respond!View attachment 509937View attachment 509938View attachment 509939View attachment 509940View attachment 509941View attachment 509942View attachment 509943View attachment 509944View attachment 509946
You may be missing a trick not including Arendal. They have astonishingly low distortion and also produce solid bass extension.
Neumann then.
KH150
Frequency_response
Looks
cheers
interesting, hjavent considered these yet. Will do some research, thanks.
i compared them to both at multiple occasions and diferrent rooms. Looking at the measurements i thought apart from the bass extension the Ref 1 would sound similar to the R3 meta, so i was suprised that the Ref 1 sounded better in every regard to my ears. I also prefered them compared to the reference 3 metas. They had more midbass output but i subjectively found the reference 1 more ,,coherent'' and ,,transparent'' for a lack of a better word. I am not sure why that is. Maybe the reference 1 has less issues vertically because there is no driver above the uni-q but i am really not sure. I cant really find any explanation in the measurements. might have also been the rooms.
true but they are a bit too wide for my set up and also arent quite as good dispersion wise.
Where exactly do you see lower distortion on the KEF? the only distortion issues that might arise with either of these speakers is in the bass and the ascilab is quite abit more composed there.
I was thinking about getting the Reference One metas (or LS60s) but stumbled upon this thread and am considering the S6B or C8C.
Integrating an active should be okay for me, since I have a X3800H with pre-outs and Dirac ART (w/ 2 SVS 3000 micros). My room is 24' by 12', with the speakers roughly halfway along the long wall (so speaker to couch distance is ~9 feet), but one side of the room opens to pretty much an open plan kitchen/hallway. There is also the TV of course. I have 6 inch thick panels behind the couch as well as an 8 inch panel behind the LRs. Use case is mainly music, with TV/theater being secondar.
Is there any reason based on this setup to prefer Ref Ones vs one of the Ascilabs? Maybe this is a good case for cardioids since the room is kinda odd. The only downside seems to be vertical directivity.
If you care about grills and looks mostly. Although vertical directivity isn't nothing either, if you have ever need to get up and move around there's a pretty substantial sound difference from having better vertical directivity, you don't get the sudden dropout in clarity.
There isn’t a sudden ‘dropout in clarity’ when you stand up, the C8C/BX8C together are around 140 cm tall.
