Goldhamster916
- Joined
- Oct 4, 2023
- Messages
- 255
- Likes
- 212
- Thread Starter
- #101
I appreciate the alternatives but without independent (klippel) data I wouldn’t buy any of those.The room is not big and 2-way with 6.5" woofer will fit fine there - you'll get 45Hz -3dB, your small room will add support on bass and you will not feel lack of bass. You'll get same with Kef Ref1 or Purifi 6.5-based speakers.
Sure, if you want a kick in chest you need to go to higher caliber for woofer.
Kef Ref 1: while it measures well I cannot listen them long - there is something what start to irritate my ears.
Purifi PTT6.5W Alu based speakers: they are nice drivers, but you cant fool physics - mms is more then twice higher if compared to SB Satori MW16 drivers, the midrange will not be that good and detailed, while Purifi's bass and power handling will be better then Satori MW16. If you for "soundpressure", and mostly listen to pop where you need to feel base then Purifi-based speakers is what you need.
If you want retrieve more music details and get a speaker what will please you I suggest custom builds based on SB Satori drivers.
With your budget you may go with re-workerd SB ARA with Beryllium tweeter and MW16TX-4 Textreme woofer.
SB Acoustics ARA Beryllium dome Textreme Light Edition - FineTuning by StereoArt
or
SB Acoustics ARA Beryllium dome Textreme TOP Edition - FineTuning by StereoArt
TOP edition is my favourite bookshelf and can compete with many from crazy-priced high-end 2-ways of a same size.
Will cost less then Kefs or Ascilabs, will measure same or better, but definely will be more interesting to listen. Drivers and internal components are unbeatable top-level products.
