Jiraya369
- Joined
- Sep 2, 2025
- Messages
- 539
- Likes
- 517
you wont hear much except for the slightly deeper bass on the S6B and the wider horizontal dispersion, meaning a wider soundstage. That's basically it. The coaxial nature of the Ref 1 Meta means if you move your head like 40 degrees below the reference axis, you can still get a good sound, not the same thing for the Ascilab but due to the low crossover you can go quite low and still get a great sound, and vertical dispersion is top notch on both.
Get whichever is cheapest, is easiest to place and most importantly looks best. Endgame is a mindset, if you get something which looks genuinely good to you, then you're done.
Make sure to budget in some subs and measurement mics
