I've been here for years and yet just recently upgraded from Spotify through my Denonx4500 to an Eversolo DMP-A6 pushing Qobuz through the same Denon, and my goodness, what an improvement. Shame on me. Some of us are slow or clearly don't understand what's possible...
I bit the bullet on end-game upgrades and would like feedback if I'm missing another obvious or easy improvement.
Basement room is 12.5'x20'x88" (narrow and low!) with bass traps and first reflections absorbed (4")
Inbound:
Marantz AV20 with Dirac ART. 60% stereo, 40% HT
New Revel Salon2's and a Voice2
Buckeye purifi 3 channel with 450watt each @4ohm
Already here and solid
4x SVS subs, one in each corner
11- channel Monolith amp
Here and questionable:
Eversolo DMP-A6 and -A8. Which should be kept if just a streamer into AV20 using DSP? I got the A8 after the A6 due to the DAC, but now learned it's not used with DSP on the AV20 because digital signal path. Duh. What's the best solution under $2k for my use case?
Surrounds are Revel S206 bipoles. They're terrible for multi channel stereo but that's ok cause I listen in stereo. But for Dirac ART and Atmos, it seems I really should switch to standard config. Space is an issue with narrow room and low ceiling so either angled or in wall. Budget prefer around $1k per but can increase if worthwhile. Recommendations?
Ceiling are Klipsch CDT-5650-C II. $150 each. I'm thinking who cares and they're fine...?
Please share thoughts and advice. Thanks.
Inbound:
