Ok, so here is the skinny … Soundfield definitely sent me down the rathole by providing a choice between the coaxial and planar drivers … if I had heard just one or the other I would have been totally happy in my ignorance
But alas in Soundfield’s quest to have the happiest customers in the biz, I was presented with options. I have spent countless hours going back and forth between the two drivers and after all is said and done, I am going with the planars. But the coax is truly excellent, again had I never heard the planar I would have been in heaven. Amazingly enough, for two very different driver technologies, they sound more the same than different. I should note the planar is effectively a point source just as the coax due to how Soundfield has implemented the design.
So, how do the planars sound? (be warned a bunch of subjective audiophile blah blah follows) …
Astonishing level of resolution and detail (hearing details in recordings I have never heard before)
Disappearing act like I have never heard with any other driver … the speakers are just gone
Larger soundstage, very holographic
Highly precise imaging, but maybe a bit more diffused than the coax
More dynamic
Very transparent… if it’s on the recording, you hear it. And this is one of the cons (though I don’t see it this way, some might), bad recordings are a no go with the planar, a true window to the source
Coax again sounds very, very good, but it just does not match the planar in the areas described above except where noted. I would say it does just ever so slightly have a more precise image, planar just a little more diffused, but it is a subtle difference. Also every now and then on some recordings the coax would call attention to itself. As to the transparency, and some may find this a positive, the coax is definitely more forgiving of poor recordings as it has a “darker” sound for lack of a better word.
I should also mention the final design is different than the renders I provided prior. Primary reason is taking a more systems approach to the room rather than putting all the eggs in the mains bucket, so to speak. Especially as it relates to LF distribution around the room (multi sub approach basically)
Mains: Front planar midrange and supertweeter, rear planar/tweeter (reminder Soundfield has variable directivity capability, hence the need for the rear drivers) … so there is a narrow, wide, and “concert hall” mode. And as typical with Soundfield, full range cardioid midrange to 40Hz, monopole to 20Hz, via upper 1x 14” woofer and lower 15” woofer.
Center: Tower, match of mains (no horizontal center in my room!), but smaller woofer complement, so less LF extension (down to 40Hz), also cardioid. Basically center channel is a “slim” version of the main
Rears: Up firing ambiance drivers with cardioid LF
High output LF sub (<40Hz coverage): just behind listening position, will be dual 15 or 18, TBD
Soundfield finalizing design with cabinet maker, hope to have the system in place within next 2 months or so! I can hear my sons back of car when they were little guys on a family road trip … are we there yet dad? Just a bit longer kiddos, just a bit longer …
