End Game Speaker Quest - The Final Chapter
In case anyone wondering what the layout would look like if I go with coax in final design, a very basic render …
Why not make smaller speakers and use subs?
With these giant towers you still have to deal with nasty room modes.
And how have you come to that conclusion? Note I will in fact also have subs.
Then why such a large cabinet?
Sorry, not sure I am following. These are full range mains with cardioid down to 40Hz which will resolve much of the typical LF interaction issues. But I will also have subs for that last bit of LF extension, but NOT because they are needed to correct any LF room issues, they are not. And note I am generally not a fan of small speakers and a big believer in full range mains if the room can accommodate.
And again, what is your reasoning to support your conclusion that there will be "nasty room nodes" with this particular system?
I have no experience with cardioid bass, but assume you are correct in your choice to tame room modes.
That said, looking at the rendering and drawing above, I am less confident that you won't experience some "nasty visual room interaction." AKA a negative WAF. :)
Reactions: MKR
Would you cross to subs around that 40Hz mark? I wonder if crossing higher would negatively affect the cardioid feature's positive effects.
Reactions: MKR
Correct … will cross around 40-50 … exact point pending measurements/analysis of actual room response
Not sure what is wrong with the looks, form follows function. And note I prioritize performance over looks. But looks are not fully irrelevant of course. Ultimately these will look very nice in their final form. I guess you are wanting to see a giant horn? Maybe a Meyer Bluehorn? Talk about WAF issues ;)
But in the end, doesn’t matter, as this is MY dedicated listening room, can have whatever I want. The wife could care less (she gets the rest of the house :D)
Understood on the WAF, and I must say it is great to have an understanding partner in these matters. I have mostly been blessed in a similar manner by "she who must be obeyed", but for some folks staring at a pair of almost 6' tall speakers can be an aesthetic challenge regardless of fit and finish or the design... then again others like the statement.
Funny you mention Bluehorns. I have given them serious consideration. I decided there was no way to decorate them with paint or veneer and make them visually acceptable in a residential environment. As with your current project, the only way I would find either solution visually acceptable would be in a dedicated room with an acoustically transparent fabric wall. In cases like these, I think no visible speaker would be my choice.
I have been living with large horn speakers that sound fantastic, but I am kind of over looking at the hardware and would love to eliminate the elephants in the room.
“She who must be obeyed” LOL, love that
Which horns are those? JBLs I assume? Nice looking speakers!
Sorry the Bluehorns didn’t work out :(
Th
I wish I could claim it, but I borrowed it from Mr. Rumpole.
The 15" woofer is a JBL that was developed for the original Revel Ultima Sub, the other drivers and the horn are from TAD.
Th
So basically a DIY speaker? Active or passive?
Those ggntkt look so good.
I know right! End game for me as they are potentially financially viable in a couple of years. Doing something like MKR’s project is a bit far off what I can imagine any future budget to be, but amazing if you can do it.
Reactions: MKR
Agreed … I really like the understated elegance of the GGNTKT … they were on my short list for a time, but limited (none?) availability in US and no way to audition here
