prestigetone
- Joined
- Feb 12, 2021
- Messages
- 405
- Likes
- 492
Yes. Always interested in logistics of something like this.Sorry, not sure what you mean by “handled”? I assume you mean who is responsible for cost?
There’s a drawing of what they are expected to look like. As I understand it, what MKR will have to listen to first will be prototypes. This is a collaboration between the builder and the customer.Is there a photo of the speakers?
By my experience,room volume counts,and counts a lot,in fact it dictates what kind of speakers it needs.I have no doubt that your new speakers will sound phenomenal. There's something truly special about the sound produced by 7 to 8-foot tall speakers that's simply unmatched.
Our perception of sound varies significantly at different volume levels. This variance can be even more pronounced with large, multi-driver speakers. Without sophisticated dynamic EQ systems that adjust frequency response based on volume, and highly efficient driver designs that maintain dynamism even at very low levels, listeners might notice a lack of vibrancy at softer volumes.
Many high-end tower speakers are engineered with larger rooms and higher volumes in mind. Their voicing and overall design often cater to these conditions rather than background listening. Moreover, large speakers interact more substantially with the room, especially in terms of bass response. This interaction becomes more evident at higher volumes, contributing to that "fantastic" sound you're anticipating. At lower volumes, however, room interaction is less perceptible.
Large multi-driver speakers excel at producing high sound pressure levels (SPL) without distortion, which is ideal for loud listening. But at lower volumes, not all drivers may be fully engaged, potentially diminishing the perceived dynamics. Additionally, the complex crossover designs in tower speakers, designed to distribute frequencies among multiple drivers, are typically optimized for higher listening levels where all drivers are fully active. At lower volumes, some drivers may not receive sufficient signal to operate optimally.
When you audition your new speakers in your space at various SPL levels, you'll quickly discern if they might benefit from a finely tuned "loudness" curve that automatically reduces as volume increases. This feature implemented effectively by RME, can greatly enhance the listening experience especially at background music levels.
Thanks for your additional explanation. But I am not following the logic here. With this design there is no “voicing” or specific attributes that would make it any less capable at lower levels vs high SPL, but it certainly is capable of higher SPL vs a generally smaller system (obviously). I also do not understand your comment that not all drivers are “fully engaged” at lower volumes. What does this mean? All drivers are fully “active” all the time and the crossover (DSP) is not optimized for high or low levels, it will be optimized to have as flat FR as possible across the frequency spectrum. And once again, one of the primary goals of this design (as with any Soundfield design) is to remove the room from the equation as much a possible. This is especially true with the full-range cardioid capability and variable directivity.I have no doubt that your new speakers will sound phenomenal. There's something truly special about the sound produced by 7 to 8-foot tall speakers that's simply unmatched.
See first post. System only exists on paper, design in progress.Is there a photo of the speakers?
This is correct. There is a first-pass high level design, more detailed design work already started on the bass modules. However, the mid/tweet module design is still TBD pending the outcome of the upcoming demo (coax vs planar).There’s a drawing of what they are expected to look like. As I understand it, what MKR will have to listen to first will be prototypes. This is a collaboration between the builder and the customer.
Only if the planar works (sounds) better in my specific room. The planar has wider dispersion characteristics than the coax and that may be problematic in my smaller room. This is why it is so important to have the in-home demo, really the only way to know for certain what will function best in my space and preference. Typically I prefer wider to narrow dispersion, and usually why I have never been a big fan of coax drivers, but that may not be the end conclusion in this case.Is there any reason not to choose the coaxial driver?
Interesting (and cool) idea of course, but my expectation is there will be a single solution that sounds best in my room, will be no need to switch between the two types. Also the on the fly (Hypex remote switchable) variable directivity will allow some level of adjustment similar to having “swappable” mid/tweet module. Finally, there is a rear “effects” planar regardless of the front facing solution that would make such a solution even more complicated. And yes, even if possible, would be more expensive and maybe push over my budget.Why choose between planars vs coax? Have them both mounted on a rotatable module. The active set would be pointing forward, and rotating the module would also automatically adjust the DSP settings in the bass modules to match the active set. This way you can have the best of both worlds for different genres. Not sure how much a mod like this would cost though... Could also add a remote control to actuate motors to do the job for you, rather than doing it manually. That would be impressive!
Got it. Especially understand your curiosity given the terrible shipping situation you experienced with the Geithains. Soundfield uses very stout custom wood crating to ship their larger speaker systems.Yes. Always interested in logistics of something like this.
Planar midrange is the GRS PT5010 (the former BG Neo) and the coax is the 12” BMSThat sounds fun. Lots of options for sound tuning. Do you know what model the drivers are that you will be comparing?
Well said … of course the intent is that it be monumental, else the “end game” moniker is quite inappropriateThis really is going to be a monumental system. Not cheap, but does seem to me that for what you're going to be getting and considering that it's a totally customised solution, it's remarkable value for money.
LOL … the “MKR”, now that has a nice ring to it… though my signing fee will be much higherActually, this is pretty good PR for Soundfield. I can see once all drivers are tested and selected by MKR there may be a new speaker model available from Southfield called the "MKR" with signed additions available for $100 more.![]()
The signed edition includes two years of ASR transcripts published as a mini-book to read while you enjoy your speakers....Actually, this is pretty good PR for Soundfield. I can see once all drivers are tested and selected by MKR there may be a new speaker model available from Southfield called the "MKR" with signed additions available for $100 more.![]()
