Ok, let’s cut the speculative chatter about the OP unless you have some proof. In that case, it should be reported to the staff for investigation.
Thanks for your cooperation.
Great thoughtful questions as always @MattHooper@MKR
It’s been such a journey. I can’t remember if you’ve already given this information but:
1. What speakers will these new active speakers be replacing? I’d be curious about your speaker owning history.
2. Have you posted any pictures of your room where the speakers will be placed? Is your listening room otherwise complete and how you want it?
As to my speaker history …. Aerial Acoustics 10T -> Talon Audio Khorus -> Linkwitz Orions (the original design) -> JBL Studio 590s …
No pics of listening room, but it is 13’x15’x8’ over garage “bonus” room. Not large by any means (and not near as large as initially planned), but not necessarily small either. Someday I hope to have a larger room, but this will do for now. Room is finished/complete. And outside of typical home furnishings, zero room treatment. Once I have the final speakers in room will certainly be sure to post some pics. And a reminder as I have stated prior, this will be a dual purpose theater/music system, and will eventually have a front projection system. Was considering LED panel, and may still go that path, but front projection better for acoustics as I can run the front channel behind acoustically transparent screen, rather than having to mount a panel quite high to clear the floorstanding center channel.
Interesting! It’s been many years, but I remember being quite impressed with the Aerial Acoustics 10T. It sounded generally quite neutral, and as someone who grew up listening to KEF 105.2 speakers I recognized the form factor.
I’ve always wanted to hear a Linkwitz speaker.
Most interesting is that you had the Talons
That speaker was “the buzz” among the audiophiles for a brief time long ago. I actually ended up trying the bookshelf version of the Khorus in my home. (the less said about that the better). Did you like the Talons?
By coincidence that’s the exact size of my own room where I combined my separate 2 channel system with my projection based Home theatre. Wasn’t easy to juggle all those balls, but it worked out for me perfectly in the end. With persistence and some ingenuity, you can have it all![]()
I will say though the description you give below are definitely not the Talons I knew, and I heard them all. I have to believe there was something broken, but who knows. There was definitely a two camp opinion of Talon, seemed it was love or hate.
Your prior comments for others background:
“A pair of Talon Audio stand mount speaker (Peregrine IIRC). Talon had huge buzz back around 2000 with their big Khorus speakers and I ended up with a pair of their then-new stand mounted version in my place for a while. I could not believe the sound - the most colored speaker I'd ever heard - muffled, dark, weird dips here and there, bulging upper bass etc. I was sure they must have been broken in transit. Sent them back and...nope...that's how they were supposed to sound apparently.”
As to the room, I have seen pics of yours and it looks great!
What front projection system are you using? And what are you using for a processor?
Indeed I am aware of those Khorus measurements and they aren’t good for sure. But, to provide the full story, when i first got my Khorus in fact I was not so impressed, with similar impressions to yours (though not quite that negative, i still enjoyed the speakers very much, but there were clear issues). Very long story short, there was a “rev 2” Khorus with different crossover and mine were upgraded with new crossover and it was then that I became quite smitten with them. Much improved. I don’t know for certain, but I don’t think a Khorus with this new crossover was ever measured by anyone. Anyway, they were a bit of a “first love”, we always seem to have positive memories of our first love, even if not trueOut of curiosity, have you ever looked at the NRC measurements of the Talon Khorus?
Here they are:
And that’s pretty much how the smaller model sounded to me. It seems they had a certain house sound going at that point. (I’ve heard from more recent owners that they’ve updated their design to be more neutral).
Much obliged
I’m using a JVC RS600 projector that I bought back around 2016. It was their first 4K capable projector - Eshift - and also I believe it’s still the highest native contrast projector they’ve produced. They’ve moved onto laser based projectors which are priced way out of my reach at this point. But those tend to have lower native contrast. I have a Lumagen Pro VP ready to do HDR processing for my projector, but I still need to upgrade my HDMI cable to be able to run 4K HDR.
I tried to keep my room as uncluttered as possible, so my projector is sitting on a lift hidden behind the sofa. When the home theatre mode is activated, the projector lifts up to over 6 feet turns on and is ready to project onto my screen.
I’m using a Stewart ST130 white screen - I generally find the screen artifacts on ALR screens to be intolerable, and so I chose a white screen along with controlling light reflection in the room to maintain high contrast.
The screen has a four-way automated black velvet masking system that I sort of put together from two different systems, so that it can change aspect ratio or size as I desire with the image area always perfectly masked (that might’ve been the best decision I made in my whole home theatre).
The screen goes up to 124" wide for CinemaScope, and up to around 128" or so diagonal for large format 16:9/1:85:1/IMAX material - seating distance is 10 to 11 feet at the sofa.
Probably more than you wanted to know… but ask a home theatre geek a question and...
Indeed I am aware of those Khorus measurements and they aren’t good for sure. But, to provide the full story, when i first got my Khorus in fact I was not so impressed, with similar impressions to yours (though not quite that negative, i still enjoyed the speakers very much, but there were clear issues). Very long story short, there was a “rev 2” Khorus with different crossover and mine were upgraded with new crossover and it was then that I became quite smitten with them. Much improved. I don’t know for certain, but I don’t think a Khorus with this new crossover was ever measured by anyone. Anyway, they were a bit of a “first love”, we always seem to have positive memories of our first love, even if not true… these days I consider myself much more enlightened in this hobby and I suspect the Khorus might run me out of the room if I heard them today.
Wow, seems I asked the right fella about theater topic! Very slick setup you have there. I might pick your brain a bit going forward if you don’t mind. Note projector I am considering is the Valerion VisionMaster Pro 2. Seems tough to beat for the money. Know much about it? I plan to have a drop down acoustically transparent screen.
Hey @steve59! Great to hear from youCongrats!!! It has been an interesting journey and when you posted considering both planar and coax switchable I thought it was a recipe for misery. Spending the entire listening session listening to the speakers instead of the music.
I forget if they're fully powered or just the bass modules? Also being DSP based you'll need access, I've got some Meridians that offer limited control thru a tablet using their software. I am interested how Soundfield implements DSP. 2 years of earning interest on $20k likely covers the sales tax![]()
… in that they sounded more similar than different, so took forever to make the choice. I got to a point of paralysis by analysis and forgot about the music. I eventually came to my senses, and pulled myself out of the rat hole. While again both drivers excellent, in the end the planar ticked off more of the boxes and simply made me happy. It is a testament to Soundfield's design ability that two very different drivers sounded more the same than different!I eventually came to my senses, and pulled myself out of the rat hole. While again both drivers excellent, in the end the planar ticked off more of the boxes and simply made me happy.
LOL … thanks, I am going nuts. Well, it’s been about 3 years or so since I began this insanity, so I suppose another 1-2 months won’t be the death of me. Cabinets are complete, but made overseas, on their way to Soundfield for assembly and testing.it's October, i think i am more anxious for you to get these speakers then you are.
Congrats btw can't wait to see the final product set up and in your room.
So when is the listening party?LOL … thanks, I am going nuts. Well, it’s been about 3 years or so since I began this insanity, so I suppose another 1-2 months won’t be the death of me. Cabinets are complete, but made overseas, on their way to Soundfield for assembly and testing.
That is the $30,000 question, isn't it?So when is the listening party?
As soon as I have them in my possession! Seriously, for those that are in the area (Boise,ID to be exact), or even those that are willing to travel, y’all are welcome to stop by for a listen any time.So when is the listening party?
